Can the (cut) wiring be repaired on headphones?
I was trimming some brush while wearing my noise canceling headphones. I accidently cut the cable/wire leading to the IPod. Can it be repaired?
  • birdssinging Jun 20, 2009
    Does it matter that there is some type of fiber in with the copper wiring? I have 1 green wire, 1 red wire, and a bunch of loose copper "hairs", but they all have some of this fiber material mixed in.
  • 36 Answers
Yes it can, strip the wire's off, re-connect them & tape well with electrical tape avoiding any shorts & you should be working again.
Posted on Jun 20, 2009
  • Mojorisin65 Jun 20, 2009
    The loose coppers wires can be twisted together they are the negative wire to your speakers, the fibers are just insulator & can be cut away. The red & green wires are the positive input to each speaker. You should have a negative wire & one of the positive wires going to each speaker they are actually ran around the outside of the positive (red & green) wires, if you trim back enough wire covering you should be able to tell which un-insulated copper ground goes to each speaker.
  • phil_vella
    phil_vella Jun 14, 2012
    correct on the colours etc. but you cant simply twist the wires together because they are laminated copper, there is a coating (like a varnish) which acts as insulation. The best way to deal with that is by soldering, keep the soldering iron tip (with small blob of solder on it) applied to the wires for a few seconds and the coating simply burns off leaving a soldered wire ready for joining. Its a very fiddly job, but its feasible.
How to fix a cut cord on a "rocketfish rf ca2e cassett adapter"
In the cassette is a little head, where the wires goto.
It is supposed to be two shielded wires, soldered on the head. The shield will be put together, to avoid extra hum and other noise.
If you don't have a clue, or you have to by a soldering iron, forget it, because on Ebay you perhaps find another adapter for only a few box.
Jun 17, 2014 | Rocketfish Lot Of 5 Rf-cpa3 Car Cassette...
Cuts of when walking
The headphone cable maybe faulty.
To locate the fault along the headphone wire, while you are listening to music slowly flex along he cable from the headphone to the plug in your player, When the music stops then you have located the broken wire in the cable. This can be repaired by fixing the break. You may need a friend to help you repair the cable.
Apr 11, 2013 | Bose QuietComfort® 15 Acoustic Noise...
The cable to the head phones has been cut can this be repaired?
yes it can be repaired
if the cable its cut in the middle just need to the to parts together with a knot
if calbe its cut from the joint with the headphone they need to be soldered
Apr 06, 2011 | Bose On-Ear Headphones
The sound coming from my right bose on-ear headphones
i think ur headphone wires or its pin at end will be defective..
99%there is no chance of failures in speakers ..
try to replace ur headphone cable with new cable.
just solder the cable with speaker inline pins..
May 25, 2010 | Bose On-Ear Headphones
Wire inside is torn
Hello
This tends to happen eventually with headphones, mostly by accident. I know.....
Things that you will need are a soldering iron, screw drivers and such.
You will have to disassemble the headphones, begin by removing any visible screws, you may have to carefully remove the soft pads around the ears to expose screws.
eventually you will get it open.
It is pretty simple repair. You have to cut the old wired out, possibly expose some new wire and then solder on its place.
When you got the wires in properly again, plug the headphones in and listen if you get sound from both, if these include a microphone also test it.
Then reassemble the headphones.
Let me know if you require further assistance.
Thanks,
Ekse
Feb 27, 2010 | Sentry HO900 Headphones
One of the wires inside the cord must be broken since both channels can be heard only when manipulating the connection on the source end. Any fix?
Buy a new plug at Radio shack (for instance) and solder it on to your headphone, just cut the old/broken plug off at the base as to save the most lengt of your wire. Make sure to 'burn' the ends of the wires you are about to attach(1 or 2 second flame from a lighter) they are coated, but its hard to see, burning them removes this coat making the wires able to transmit the electrical current(music, in this case :P)....IF YOU DON'T WANT TO/KNOW HOPW to solder, then I would buy the cheapest headphones you can buy(Dollar store), cut the cord off somehwere halfway and reattach that to the cord on your headphones. MAKE SURE TO "BURN" the coating off the wires for this procedure to, or they will be together, but they wont make any contact!...I've done this many times and it has always worked great fror me!...Good luck.
Jan 11, 2010 | Bose QuietComfort 3 Acoustic Noise...
Right speaker in headphone wire is broken or something, keeps going out when the headphone wire is moved. is there anyway to repair this?
The wire connection inside the cable is broken. You can disassemble it, cut the wire past the broken point (usually where it makes a sharp bend) and re-solder it. If the wire is too short, you need to get an new wire or get the wire from a donor headphone and replace it.
Aug 29, 2009 | Skull Candy G.I. Consumer Headphones
MDR-NC6 Sony Noisecancelling headset
I think I have it. I've only had a chance to listen to a couple of songs till the brand new headset's right ear died. I took it apart and found that when I hook up another speaker in parallel with the dead one, it works, which can only mean that the circuit is fine and the 'dead' speaker is really dead. No idea where to get a replacement though.
Aug 05, 2008 | Sony MDR-NC6 Consumer Headphones
Can it be fixed or replaced?
Assuming the cord just does like any standard audio cable and transmits sound one way from the 3.5mm jack to the headphones then you could get some wire and solder it in at either end, then just use some stage tape to wrap around the join.
Were they normal headphones I'd just suggest some new ones, but noise cancelling are expensive IIRC.
Jul 13, 2008 | Sony Audio Players & Recorders
1,608 people viewed this question
 Grubhead
Grubhead
