Question about Canon PowerShot A85 Digital Camera
A85 won't turn on..
Well, it does turn on for a short period of time (less than a second) and then blinks the green "on" light once and shuts right off. For that small period of time, it attempts to open up the lenses. It is not a battery problem, as this happened suddenly without a warning.
I suspect i might have something to do with the Compact Flash card. I recently acquired a Rebel XT, and was using the 32MB CF from the A85 in the XT. I formatted the 32mb CF to the rebel xt, before I started using the XT. Once I put the CF card (full of images taken with the XT) back on the A85 (since I bought a 2GB CF for the Rebel), it will not turn on. It just blinks once and shuts down.
Any suggestions on how to resolve this?
Thank you.
  • 4 more comments
  • Anonymous Nov 03, 2007
    a80 power shot goes on, turns back off displaying E18 on lcd screen
  • Anonymous Dec 03, 2007
    won't turn on at all. at one point i turn rotating switch it tried to start and the telascoping lens started to come out and it just stopped. now nothing.
  • Anonymous Dec 15, 2007
    hi, i also have the same problem.
  • go4don Dec 25, 2007
    hi there
    i am having the same prob. with the a 85 not comming on as well.
    it has new battries and the memory card is ok.
    when turning on the lens extends and then goes right back into the camera.
    no error message's at all.
    if anyone has an idea. please help
  • go4don Jan 07, 2008
    I posted the prob on the 25 of Dec. and the Solution.
    I didn't mean the error of e16 to help but was an error that i had noticed.
    Sorry that it was posted as a solution. Wasn't meant to be
  • gaewen Jul 02, 2008
    Yes, i have the same problem but i have three different flashcards 256k, 1gb, and a 35mb which came with the camera. i have tryed all three cards that was not e problem. The camera just turns on the lense will retract and then the camera will shut down retracting the lense back in and then the green light will remain on very breify then the camera shuts off. What can be wrong with it?
Go to www.e18error.com one of the suggestions on there said to tap the usb port entry point on the desk, well we banged it rather than tapped it but it works fine now, thank you and good luck
Posted on Jun 17, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Turns on for a few seconds, turns green then shuts off.
Sounds like you have a problem with the green crt. That is the one I've most commonly seen fail first. Your tv has three picture tubes in it that can be accessed from the front of the set. The picture tubes(crts) have a filament inside the neck like a light bulb has a filament. Over a period of time tiny particles burn off and the debris can cause a short circuit from one piece of the filament to the other. The tubes are no longer avail. as a new replacement part but the tubes in your set can possibly be saved. One trick is to lightly tap on the neck of the tube with an insulated post or screwdriver handle. Right when you turn the set on and it goes green sometimes you can lightly tap on it, (the middle tube) and knock the debris free removing the short. If that doesn't work the tubes can be rejuvinated/cleaned using a machine found in most repair shops known as a picture tube rejuvinator. My experience is that this procedure should cost 100.-200. plus service call. Most service people will tell you that this is not a guaranteed fix, but 90% of the time it works and you can get years of more use from the tv. Good luck, Russmann.
Oct 19, 2009 | Sony KP-57WS500 57" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Canon PowerShot A85 Digital Camera Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
