Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Green flashing light - no picture
While watching the TV, the picture went blank. I've done a reset as recommended on sony's site, unplugged the TV, let it cool, etc. When I try to power it on, the green power light on the front blinks constantly, with no picture. I've also plugged it into the wall, removing it from the surge protector. I hear a sound (power supply?) when I turn it on, but no picture...
Any suggestions?
Re: green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Posted on Nov 08, 2007
0 characters
3 Points
I have a Sony KDS-60A2020. TV went blank. No flashing lights. I have sound, but the screen is blank.
have you tried a power reset, unplug all components from the TV unplug it from the wall, then push and hold the power button for about 30 seconds, then plug all components back in, plug it into to wall then turn it on again.
Jan 14, 2012 | Sony KDS-60A2020 60" HDTV
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture and sound shut off, blinking green standby
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
50 inch Plasma problem
Most likely a capacitor in the power supply went out. otherwise it may be a bad relay if there happens to be one.
Most reason for a tv not turning on at all is bad power supply
Aug 01, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
May 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Oct 11, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
396 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
