Question about Sony KV-20VM30 20 in. Combo
Vcr is trying to eat tapes
When i put a tape in it tries to eat the tap by pulling the ribbon out, and it also cuts the tv off
  • 3,230 Answers
Cassette tape is pulled through the player by a mechanism that engages the
little internally-toothed wheels that have the tape wrapped around them.
This mechanism can get broken, worn out, and/or dirty. When its not working
right, the machine tends to eat up tapes and trash them.
an it cut's the tv coz. of no signals.
follow the below link for more info -
http://www.epinions.com/content_1891868804
Good Luck!!
Thanks
Posted on Jun 20, 2009
I have a phillips combo tv/vcr working perfectly but when I insert a vhs tape it rejects and switches off. I have tried many tapes all working in my other vcr.the tv is working ok.
VCR ?? With the possible age of the device, there could be a lot of issues with grease that is old, belts that are stretched etc. A VCR senses tape tension in order to prevent eating the tape. Clean the unit and check all the belts.
Jan 28, 2017 | Televison & Video
Went i put a tapes my vhs it just eating the tape up and it cuts off
You need to purchase a VHS head cleaner or clean the heads and pinch rollers by hand. remove cover and lid to drive system. you will see all the tape guides, rollers and heads. use Q-tips and denatured alcohol and clean every thing the tape touches. swap q-tips as they get dirty.
May 07, 2014 | Magnavox Dvd Vhs Vcr Player Recorder
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
VCR will not eject tape. Is there a mechanical override?
try taking the housing off the machine and inspect to see if the tape has been wraped up in the drive or tension pully. chances are that the tape has jamed up. you will have to cut tape out.
not the case of the tape but the ribbon itself.
Jan 13, 2010 | Sansui VRDVD4005 DVD Player/VCR
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
VCR problem in EWR2OV4
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle. The pincher wheel can become worn and/or dirty from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out than can be wound up. You can try using a re-grip solution on the idler tire or replace it.
- Jim
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
VCR eats the tape
you have a bad take-up reel clutch or a belt on the bottom of the player mechanism that is causing this trouble.
Apr 12, 2006 | Philips VR630 VHS VCR
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
