Question about Bose TriPort Consumer Headphones
Need to put a new jack on my dynamic stereo headphones, how
Headphones have two wires, of course, but whithin those two wires is a cluster of red wires and a cluster of copper colored wires on one side then in the other side is a cluster of green colored copper and a cluster of copper colored wires. On the new jack there are two tabs, one in the very center, another in the center but separated by an insulator then on the outside is a taller tab thats more like a half jacket with a hole in it and it is part of the jack that the outer collar screws to. How do I wire them, thanks
dauphine
  • 207 Answers
SOURCE: My cat chewed the wiring on my Bose in-ear headphones
Of course. Just peal off the main isolation and connect wires according to color of their individual isolation. You can just twist them and wrap them with duct tape or solder them and wrap with duct tape.
My cat recently chewed trough 220 Volts stereo power cord (fortunately unplugged) and trough speakers cable too. They work perfectly again after quick fix while my room has become off-limit zone to my cat. ;-)
Better get your tomcat fixed or find him a girlfriend unless you'd like to risk him getting killed when he starts chewing some power cord.
Posted on May 10, 2008
  • 11 Answers
SOURCE: Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Posted on Aug 27, 2009
SOURCE: Can bose wires be splice?
My cat chewed my bose headphone wire in two. Can the wire be spliced back together?
Posted on Sep 05, 2009
  • 34 Answers
SOURCE: Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Posted on Sep 19, 2009
SOURCE: wire has been cut
get a different pair of headphones. then take your bose take off the cloth covering the speakers. unscrew the two screws one on top one on bottom. take out the speaker. unsolder the leads on both. take out the rubber cover from where the wire comes out of the headset. throw the wire away. take the other headfone. cut them right before the speakers. ipod headfones fwork great. take the two wire solder them to where u just un soldered the bose ones. leav i little slack in the headset. then glue where you took the rubber covers off. this is important so when they get caught on something it does not rip the leads off of the speaker. wait for gue to dry. test out the speakers. after that put speakers back in and screw them back on and put the cloth back over them. i just did this 10 minutes ago they work so much better. i did try to splice them but this way is so much better and you dont have to worry about the slice point ripping out of place.
Posted on Feb 15, 2010
Can i hook up my PC to my sterio system through the headphone jack on the stereo to the PC HEadphone jack? been trying to get it to work on Auxilary but no sound :( please help
If you are still working on the question you asked about. This is what I would do. One of two things:
First: purchase an adapter that goes from your laptop 3.5 mm headphone jack to the microphone input if there is one.
Second: Would be to purchase what is called a "Cassette Tape Adapter". This will take your 3.5 mm headphone jack and play it through your cassette tape area of your stereo.
I hope one of these is a solution that will help you. -- wicc --
Aug 16, 2012 | Computers & Internet
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I have Radioshack wireless headphones with a 30 foot range. I cannot hook them up to my new Panasonic Viera 42 inch HD T.V. - The "audio outlet" is a square and the headphones only have red and...
hi there.
At present, the square connector is what is called an "Optical" connector.  It's purely digital and transmits digital data via what looks to us like a RED LIGHT.  Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections.  The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket.  a small round hole that looks slightly larger than a pin head.  It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
http://cgi.ebay.co.uk/1-2m-3-5mm-Stereo-Jack-2-X-RCA-Phono-Plugs-MP3-/270689011629?pt=UK_Computing_CablesConnectors_RL&hash=item3f065287ad
or this :
http://cgi.ebay.co.uk/3-5MM-STEREO-JACK-MALE-2X-RCA-PHONO-FEMALE-ADAPTER-/360300626060?pt=UK_Computing_CablesConnectors_RL&hash=item53e397408c
Sometimes the colours of connectors vary.  Just remember that Red to Red (for right hand side)  and White to White or Black To White  or Black To Black (for left)
Jan 07, 2011 | Audio Players & Recorders
I have a pair of tp-1a headphones. The headphone jack broke off. What do I do to replace it.
If you want to fix it yourself go to partsexpress.com and buy a new headphone plug. You can go to radio shack, but their headphone plug is very large but you won't need to solder anything. Cut the wires and strip off the plastic. You will see very small wires coated in red and blue if I remember correctly. You will need to separate all little wires so the colors are together. The color coatings need to be removed. Put them in the flame of a lighter for just a quick second. The coating will burn off. Scratch off the excess with your fingernail.
You will need to plug the new headphone plug into an ipod and touch the wires to the connectors to figure out which wires are for the left and the right speakers.
Solder the wires to the new headphone jack. You will find the partsexpress jacks are much better than the original.
If you use the radio shack plug you may want to put a little hot glue with a glue gun around the wires before you close it put or the wires will pull out easily. The parts express plug, link below, has a tight grip on the wires and there is no need for glue.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=092-333
Dec 24, 2010 | Bose TRIPORTĀ® Headphones
Gauge cluster lights won;t light - replaced cluster, dimmer switch - did put new stereo in car? Fuses, bulbs all good. What could be the problem?
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 28, 2010 | 1995 Honda Accord
My Sennheiser HD 205 suddenly had a problem with its jack. You have to move its top, nearest to the cord, to get a sound on the other ear, probably it was pulled and something went loose. I spliced it open...
The two copper wires on your headphones are independent grounds for each channel. Twist them together and attach them to the ground cable ( black) of the new plug. The colored wires of the headphone correspond to the live wires of each channel, and the plug should have the same colors. Wiring together the grounds will not affect in any way the stereo separation, it is just that each ear needs its own ground. Cheaper headsets just transfer the ground from one ear to the other one through the metal headband.
Oct 06, 2010 | Sennheiser HD 205 Professional Headphones
Replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
May 14, 2009 | Sennheiser PX 100 Consumer Headphones
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
HEADPHONE SPEAKER WIRING
try using colored wire with the copper....colors act as sound carriers and copper acts as power only connect the copper one with ONly 1 color tho .......just try having everything on and just touching the wires together before sodering
Apr 05, 2008 | Hitachi DZ-MV730A DVD Camcorder
Wiring code for the jack?
You're right on the code, with the exception of the right and left. I'm an AKG dealer and spoke to their service department. Here goes:
White=Ground
Yellow=Left
Red=Right
To confirm this, I used a multimeter in continuity mode and tested them. This code is 100% correct.
Nov 08, 2007 | AKG K 240 Studio Professional Headphones
Bose TriPort Consumer Headphones Logo
305 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
