Question about Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver
Minn Kota 24v auto pilot. will track correctly
Minn Kota 24v auto pilot. will track correctly and then at random turns around and around. sounds like others have this poblem
  • 76 Answers
Usually this means that there is a crack in the coil cord or there is something metal close to the head of the motor.
The coil cord can be checked while you are out fishing next time by grabbing the cord (black coiled cord from base to head of the motor) and stretching it and pulling on it. If the motor reacts to the pulling then that's the problem.
best of luck!
Mike
Posted on Sep 26, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    Minn Kota riptide ST green ready light will not turn on. It started flickering and will not turn on now. Pressed the battery test button and it shows that the batteries are fully charged. HELP!!!
    Does the unit work without the auto pilot? Sounds like the auto pilot or the reciever is not functioning correctly.
    Check and make sure the unit is grounded properly, you may need to run a test ground wire from the battery to the motor istelf to check this.
    This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to check any circuit breakers
    Try cycling the auto pilot though the modes.
    there are 3 modes
    to cycle through each mode
    hold down the + and - key for 2 seconds
    this cycles you to the next mode. Last but not least, try turning the unit on and spinning the prop by hand to see if it takes off, the motor migt be bound up slightly or have a bad spot on the brushes.
    Dec 25, 2010 | Minn Kota Riptide St Saltwater 101 Bow...
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I need a new control board for my Minn kota MKJG
    possibly someone could but the cost will prohibit it new boards are a lot cheaper if you can get one .http://www.trollingmotorparts.com/
    May 26, 2010 | Boating
    Is a minn kota mag 36 just 12V or 12V -24V run
    I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
    Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
    GPS Logo
    219 people viewed this question
    Top Minn Kota GPS Experts
    Marvin
    Marvin
    Will Halftowaite
    Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
