I need to replace the chip 478b, because to pins are broken off. I want the same or a compatable one for my motherboard P4 X 400DBP. Where to get/buy the chip would be a good start. Intel P4 processer mPGA478B.
  • arnelo1 Jun 20, 2009
    sethvel1: you got to me fast, I forgot 1 thing my cpu is a 2.60ghz I need at least that size or a compatable larger size if possible. I did not know how to grade you above, but I will later. Thanks I hope you got an answer for my problem
    sethvel1: I did go to the place you gave me and they do have a 800 if that would work let me know that also, thanks again
  • 334 Answers
Hey man, found you one cheap at the following link. Don't forget your thermal paste, very important.
http://www.weirdstuff.com/cgi-bin/item/13363
Posted on Jun 20, 2009
  • seth veloso Jun 20, 2009
    ok sorry, I'll find ya one for the motherboard you stated.
    here you go man, check these out, perfect match for ya
    http://www.amazon.com/Intel-Pentium-2-53...
My motherboard processor socket pins aro broken
If the pins are broken you will need a new CPU chip or replace the board if broken on that side of the PC. John
Apr 16, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Can i use 20pin atx powersupply instead of 24pin, is it compatible to ep-5ela-3i
The 20pin PSU is for use with normal AMD (Athlon XP, Duron, and athlon64) or Intel (p3 and P4) based Motherboards, but the 24 pin ones are specifically for the Intel Xeon chips (used in servers).
Therefore a 20pin PSU connector will NOT work in the 24 pin connection slot.
I suggest you buy a adapter.
You can buy it from:
http://www.amazon.com/StarTech-com-6-Inch-Motherboard-Adapter-ATX2024MF/dp/B0002GRTZQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1308495882&sr=1-1
Please rate my solution !
Jun 19, 2011 | EPoX EP-5ELA3I Motherboard
I have a p4s533-mx motherboard with 1.7ghz intel processor, my system had 1gig pc3200 and 256mb pc400 at 400mhz ddr1 ram, now my system suddenly wont pick up the 1gig ram card, only beeps when powered up...
The RAM modules may not be compatible with each other.
Try using the same make RAM modules.
Try Installing the 1Gb RAM module without the 256Mb RAM module.
Mar 26, 2011 | ASUS P4S533-MX Motherboard
My processor is celeron 2.8ghz. which motherbored supports for my processor.?
GA-8KNXP this is a gigabyte motherboard or any socket 478B motherboard brand. Good Luck
Nov 26, 2010 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Can i put a amd processors in a dell dimension
Short answer: NO.
Long answer: AMD processors have a different pin-arrangement than found on a Socket 478 motherboard, so they physically will not fit.
Jul 03, 2010 | Dell Dimension 4550 P4 Socket 478B...
Cpu died no heat sink temp. I have a gx60 SFF
yep your mb has gone to mb heaven and good luck on finding one to replace it I own three and they are extremely hard to find, unless you want to buy it from dell and they will charge you double for it.
May 31, 2010 | Dell Optiplex GX60 PC Desktop
I have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
it support intel 478 pin processor 1.8 ghz 400 bus up to 2.4 ghz 533 BUS
May 29, 2009 | Intel D845GVSR Motherboard
Motherboard vc35
Well your motherboard has the form factor UATX. It is a socket 478 for the processor, and has 168 pin dimm sockets for memory
Visit this page and you will find a motherboard that has a socket 478 for you processer, is the correct form factor, but you will need to buy compatible memory. (184 pin ddr 400).
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138262R
Apr 07, 2008 | FIC VC 35 (CS-VC35) Motherboard
I don't know what this is
Hi
It is possible that it will work on a new motherboard as long as the cables connects it to the motherboard matches. On your new mobo you should see pins for for usb and sound to plug to the mobo..most new cases have this though so you shouldnt really need it. However if you want to reuse your case to take advantage of the chip it should fit.
good luck
smeags
Jan 05, 2008 | E-Machines T1360 PC Desktop
Computers & Internet Logo
269 people viewed this question
Alun Cox
David Payne
David Payne
