Question about Canon PIXMA MP160 All-In-One InkJet Printer
Need the set up cd
I need to install my printer on this computer
    Problem Solver:
  • 20 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi19
Posted on Sep 05, 2009
  • 50 Answers
Hi there...
If your printer is the Canon Mp-160 in the picture you posted,
then go to this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13368#DownloadDetailAct
Choose the OS you have from the drop down menu,
download and install the driver.
Follow the onscreen instructions.
If your printer isn't the Canon Mp-160, let me know which printer it is and I'll help you find the driver.
Sincerely,
Tom
Posted on Jun 20, 2009
Hi how can i set up my epson workforce 525 all in one on my computer without the installation cd?
You can download the software (the same as is on the installation CD) directly from Epson.
If you go to the following link, click ACCEPT and download and run the installation program, this will setup your printer on your computer.
http://download.ebz.epson.net/dsc/du/02/DriverDownloadInfo.do?LG2=EN&CN2=AU&CTI=59&PRN=WorkForce%20520&OSC=XP
Hope this helps.
Apr 15, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
Cd can't install printerdriver
OK you need to go into your BIOS and enable the correct option in you LPT Printer port settings, LPT setting is set to EPP in the bios & save. This should sort that problem out.
Feb 17, 2010 | Lexmark X3470 All-In-One InkJet Printer
I want to add my PSC 1610 as a network printer (it's attached to a print server device). When adding the network printer windows asks for the *.inf file... I can't find this file on the installation disk...
i have the same printer- unplug the printer usb cable- un-install the printer- plug the usb back in. when the new device wizard comes up, tell you have cd. insert install cd- browse for your cd device letter- choose that. then re-install printer- full install! will prob. ask you to 'name' your printer!- write down that name! you'll need that, as well as your psc 1610 i.d. then , if your computer is the net-work comp., you need to set it up on control panel to share. then check other computers on network and see if they 'see' the hp psc 1610 and then add them to printer sharing- this is where you'll need the 'name'. i had less problem with w98se, than i did with xp pro or home! love you, microshaft!!
good luck!
Nov 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
I need to install a Canon Laser Class 2050p printer without cd
first of all
power on your printer
after that connect the usb poat your computer
then
insert the cd and open the
after that run the setup.exe
after that restart your comptuer
and open the start and settings printer and faxes
and check the
Aug 27, 2009 | Lexmark X63 InkJet Printer
Cant instal the printer to mi computer
Setting up or installing a printer in Microsoft Windows. Issue:Setting up or installing a printer in Microsoft Windows.
Solution:There are two different methods a user can install a printer in Microsoft Windows. Below is additional information about each of these methods listed in the order we believe a user should try installing their printer in Microsoft Windows.
Before being able to install your printer you must have the software that was included with the printer. If you've lost the software for your printer you can download the drivers for your printer and use the drivers to install your printer. A listing of printer manufacturers and links to their associated drivers pages can be found on our printer drivers page.
Setup a printer using printer software
Every printer should come with the software used to install a printer in Windows. Although not all installations are the same the steps for installing this software should be similar to the below steps.
  1. Connect the printer to the computer and a power outlet and make sure it's on.
  2. Insert the CD that was included with the printer. If the CD does not automatically start the install program open My Computer, double-click on the CD drive, and then the Setup or Install file.
  3. Follow the installation wizard and your printer and its associated software should be installed successfully.
Installing a printer only using the drivers
In addition to the above steps a users can install a printer in Windows only using the printer drivers. This is recommended if you only want the printer to be installed but not the additional printer software programs that are often included with the installation and/or you've download drivers.
A listing of printer drivers and software downloads can be found through our printer drivers page.
Note: if you've installed the printer doing the above steps these steps should not be necessary unless you encountered errors.
  2. Click Start, Settings, and Control Panel.
  3. In the control panel double-click the Printers or Printers and Fax icon.
  4. In the Printers window click the Add a printer icon.
  5. After completing the above steps the Windows Printer Wizard will appear. Click Next, to start the wizard.
  6. Windows will prompt you if you're installing a Local or Network printer. If the printer is connected to your computer choose Local printer attached to this computer and click Next.
  7. When prompted for the location of the drivers for the printer. Browse the computer to the directory of your drivers or point it to the CD that was included with your printer.
Testing the printer
After the printer has been installed in Windows you can use Windows to print a self-test page to make sure the printer is working by following the below steps.
Microsoft Windows 98, 2000, ME, XP, 2003, and Vista users
  1. Click Start, Settings, and open Control Panel.
  2. Double-click the Printers or Printers and Fax icon.
  3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed. Seedocument CH000939 for additional information about installing a printer in Windows.
  4. In the Printers Properties window click the Print Test Page button.
  5. If the printer is able to print a test page, you're printer is installed and setup properly. However, if you're unable to print in other programs it's possible that the program you're attempting to print from has issues.
Mar 23, 2009 | Office Equipment & Supplies
Can't install my lexmarkx4270 to computer
Kindly click here and enter the model number. You can download the driver for the printer.
Remember that unplug the printer and that start the installation of the printer. You need to plug in the printer to the computer when prompted to do the same during the installation.
I am sure that this will help.
Please rate the solution
All The Best
Sammy
Nov 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Installlation of printer
You should try the Xerox Universal Print Driver....works for all Xerox and other brands of printers. Download is available here:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=GLOBALPRINTDRIVER&Xcntry=USA&Xlang=en_US
Jul 17, 2008 | Xerox Phaser 3310 Laser Printer
Lost printer setup CD
Try this site since your printer didn't come up from Lexmark, it might be compatible with w820 or c750.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:332:0:0
May 25, 2008 | Office Equipment & Supplies
I can not set up my printer to my computer to print
firstly u need to have the drivers for the printer, i.e the printer came with a cd written drivers, u need to install them in your computer.
if u do not have a driver cd, let me know the make and model of your printer.
Apr 03, 2008 | Office Equipment & Supplies
Printer installation
i need a installer in my printer ( Brother DCP 130C) any can help me plz...
Mar 16, 2008 | Brother DCP 130C All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
