Question about Logitech ClearChat Pro USB Headset
Left headphone stops working
The left headphone just goes dead and I have to futz with the headset to get ti working again, and then it just dies again.
  • 36 Answers
Probably a broken wire, try to isolate where it is at & then cut the wire, strip it back & re-connect & tape it up. To isolate where the break is hook up your headphones & pull, push & twist the wire all the way up to the ear piece till you find a spot where it cuts out or comes on & there is your broken wire.
Posted on Jun 20, 2009
THE solution! Just fixed it in the past hour, this guy RULEZ!
http://www.youtube.com/watch?v=S4jhWMbsHCs
Posted on Mar 17, 2012
I have bought two of these headsets, they both have done this after about 30 days, i have now opened 1 of them up and am examining to find the problem
Posted on Nov 15, 2009
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
LG HBS 700 wont stop vibrating
I fixed my Headphones that would not stop vibrating by leaving them ON until the Power drain out and they stopped vibrating. Then Turned them OFF, plug in the charger they began to Vibrate again but after the charge they Stopped Vibrating and have been ok ever since
Jun 14, 2012 | LG HBS-700 Bluetooth Headset
Had about 4 pairs of the same brand of headset and after about 7 or 8 months lose hearing of sound form the left side. Always the left. their is no sign of tear in cable from out side and it cost a lot of...
The Left Side speaker unit(driver) of the headphone is different from right side. left side has more connections and soldering points, main cable goes to left side and chances of oxidization is more, because of cable movement(if cable goes to both sides of the headset, than it damages the side where cable movement is high). try to carefully open the headset and check the connectivity with multi-meter, If it is cable problem then trim the cable and re-solder. Or as you told you have 4 pairs, and you have broken ones. swipe the speaker unit (drivers). Besides both left and right drivers have different connections, it is possible with little soldering knowledge. hope you got it. thank you
Sep 02, 2017 | Labtec Radio Communications
The left headphone on my Plantronics Gamecom Pro 1 headset seems to not be working. Occassionally upon plugging it back in (it is USB), both headphones will work, but then the left one seems to cut out...
Most headphones are sealed by clips located underneath the foam (on the ear things). Stick a paperclip or xacto knife into the hole to unlatch the clips and then pry it outward. However, check the cable for any obvious breaks before disassembling your headphones.
Dec 31, 2010 | Plantronics GameCom Pro 1 Headset
How do you disassembly right side headset to fix faulty connection
The headphone unit is sealed and cannot be accessed via the padded ear pads. You have to prise open the outer headphone cover which breaks off 4 internal attachment points (which can be re glued for re assembly). Be careful on the Left hearphone as it contains a complex electronic circuit board.
Aug 01, 2009 | Jabra C820s Headphones
The sound comes and goes from right part of headset
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Jul 04, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
May 01, 2009 | IOGear (GBE201W7) Wireless Headset
MDR-NC6 Sony Noisecancelling headset
I think I have it. I've only had a chance to listen to a couple of songs till the brand new headset's right ear died. I took it apart and found that when I hook up another speaker in parallel with the dead one, it works, which can only mean that the circuit is fine and the 'dead' speaker is really dead. No idea where to get a replacement though.
Aug 05, 2008 | Sony MDR-NC6 Consumer Headphones
Left headphone does not work properly
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
Oct 27, 2007 | Logitech 350 (980374-0914) Headset
Logitech ClearChat Pro USB Headset Logo
989 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
