Question about InFocus Projector Remote
Remote control and PowerPoint
I am using an IF24 projection. The PP presentation shows on the screen; the remote will turn the projector on and off, but it will not advance the slides. The mouse will advance the slides but the remote will not. I am a novice and it may be that I am not pushing the right buttons. I need help. My presentation is Sunday afternoon
0 characters
1 Points
My hp m3222 projector is not working with my laptop via USB cable
The USB connection only allows the projector's remote control to be used as a "mouse" to advance presentation slides on the PC and perform some other limited functions. The USB connection cannot be used to feed video or other signals to the projector. Refer to the operation manual here:
HP mp3220 series User Manual
Feb 26, 2015 | HP Hewlett Packard MP-3222 Compatible...
Panasonic TYLA1001 Lamp Reset Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation Instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Reset lamp meter on panasonic pt 56lcx 16
Turn on the projector MENU- OPTION- LAMP RUNTIME- Press and hold the ENTER button for 3 seconds. Turn off the power.
Dec 07, 2013 | Panasonic 2 Projector Lamp
Projector appears to be in lock-out (exceeding 2000hrs on bulb)
1) Press the RESET button on projector for 3 seconds or remote control TIMER button for 3 seconds and display the total lamp used time. 2) Press the RESET button on projector or remote control MENU ON button during displaying the lamp used time. 3) Select the ?0? on the screen using the MENU ( ) button or DISK PAD.
Aug 12, 2009 | Hitachi CP840/940LAMP Projector Lamp for...
Epson Powerlite 710 viewing issue
the fn + f8 should tally between the 2 or 3 different connections for it
Jul 20, 2009 | Epson ELPLP10S Projector Lamp for...
Lamp Timer Reset procedure Panasonic Projector PT-L759E
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0".
Jan 05, 2009 | Projector Accessories
Hi there
A universal remote would do the job , as long as you make sure that the Universal Remote can learn IR codes which it uses to control the Projector.
Sep 25, 2008 | BenQ 98J2032B01 PE8700-REMOTE Projector...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Whats wrong with my projector?
Hi Trezza
No this is absolutely NOT a lamp issue.
Take of the top cover and switch on the machine - check that all the fans are working.
If they are all running , this might be a faulty Mainboard.
If you can't spot anything wrong yourself , rather take it to a repairer for a proper inspection.
Good luck and thanks for using Fixya !
Apr 27, 2008 | Projector Accessories
Iamge from the previous projection from RGB still appears when i switch to Video mode. why is it?
Hi There
Looks like your Projector's Mainboard has locked the memory and is stuck.
If you can access the Projector's Menu - Reset the machine and switch it off.
If the problem still occurs , you will have to take your Projector to a Service Centre to have to Mainboard repaired.
This is 100% NOT a lamp issue.
Apr 18, 2008 | Hitachi (DT00431) Projector Lamp for...
Projector Accessories Logo
70 people viewed this question
Top InFocus Projector Accessories Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you an InFocus Projector Accessory Expert? Answer questions, earn points and help others
