Question about KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwaher stop working durning drain cycle
No power on the contol pannel.
breaker has been reset
    Sergeant:
    Champion:
  • 205 Answers
Please check the power cord.
Posted on Jul 26, 2009
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
JBP78 won't heat, breaker ok, stopped after auto clean
I need the Model # off the machine to help you.
Most comon problem with Electric range if The TOC or hi limit fuse after a clean cycle. This is usualy located in the rear of the machine behind the back pannel.
As always disconect the power to the machine befor trying to fix.
Jan 11, 2010 | GE Spectra JBP78 Electric Kitchen Range
Dishwaher will not drain!
flipped switch at fuse box, reset, ran cycle, worked....
Nov 23, 2009 | Miele Incognito G818SCVi Built-in...
My ceiling fan/light can be controlled only by the remote control. our remote is not responding with the fan anymore. it has new batteries and has power, it's just not corresponding with the light/fan. it...
Turn the power off to the fan / light by flipping the breaker or pulling the fuse and keep off for 10 seconds then turn back on, it should reset the contol receiver in the fan.
Oct 27, 2009 | Hampton Bay 24002 Ceiling Fan
My dishwasher wont turn on,or power on
Verify there is power to the electrical outlet. Make sure that a GFCI breaker has not tripped. Try unplugging it from the electrical outlet for about 5 minutes and plug it back in. Does this computer have a soft touch control panel? With the power disconnected remove the inner panel to reach the control panel board. Inspect the ribbon connector and make sure that the connector is fully inserted and has not slipped out. Check the ribbon connector for any signs of a short. My dishwaher was doing the same thing and it turned out the control panel ribbon connector had shorted across causing it not to work. If the contol panel tests good then lt could be a fuse located somewhere on the dishwasher or the computer board.
Sep 17, 2009 | Dishwashers
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Draining
just restart and let it run through it cycle
Dec 15, 2008 | Spa Parts Plus Wet End 2hp Self...
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
70 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
