Question about Electronics - Others
Arm on record player is not balanced propley - Electronics - Others
  • 30 Answers
You need to counter the weight. If it is too heavy at the needle, you may want to tape a dime on the back of the arm. If it is too light at the needle, you may want to tape a dime to the toner head (Where the needle is housed).
Posted on Jun 20, 2009
Where can I find a replacement balance weight for the stylus arm on a Anders Nicholson 2655MMO turntable, cassette, CD player/recorder?
Balance weights can be removed and replaced easily. However when you say it snapped off, that could mean damage to the arm.
If everything is OK with the weight and you still have it, perhaps the weight could be "bodge" back into place. Perhaps with Blue Tack? If after all you can get the arm to balance correctly and apply the correct pressure to the stylus it doesn't really matter how the weight is attached does it? It might take a bit longer to set up correctly, but you might save some money if it needs a complete arm just to replace the weight!
Dec 09, 2015 | Audio Players & Recorders
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Record player head goes a few songs in on start up
not sure what you mean Ryan ... do you mean the arm swings to the middle of the record when you set it down in the groove? if so the arm is out of balance and you need to balance the weight forward. if there is no weight adujustment then your works off a spring and there a million ways to adjust that. Try balancing a penny on top of the head where the cartridge is to hold it done, if this temporarily solves the problem then teh arm is out of balance.
Feb 14, 2012 | Audio Players & Recorders
I HAVE A BEOCENTER 2200. WORKS FINE ON RADIO SECTION , BUT SWITCH TO RECORDS AND RIGHT HAND SPEAKER CUTS OUT ? ALSO HOW DO I BALANCE THE PICKUP ARM ? AS SOME TIMES IT SKIPS ...
I am not familiar with the model but a high quality turntable and tonearm needs special care.
The turntable should be adjusted to be as level as possible - the classic method uses a circular "spirit" level that has a blob of mercury instead of a bubble.
The tone arm can be moved manually but great care must be exercised especially if it is fluid damped, though it is better not to if the mechanism is functioning.
It is important the stylus tip is in good condition and the playing weight is adjusted to the required value using a stylus balance.
The correct playing weight is specified by the cartridge manufacturer and the adjustment method will be described in the instruction manual.
Dec 18, 2017 | Bang and Olufsen Beocenter 9300 Shelf...
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
Record keeps skipping arm won't move toward center of record
Sounds like your arm is tracking too light. To proper set the tracking weight on most units you need to zero the arms balance so that it is balanced just at the surface of the record. Once that is done using the weight on the back of the tone arm, or whatever system your unit uses, there should be an adjustment by turning the weight on the arm or perhaps a lever near it. You owners manual should really explain all this and give the recommended tracking weight in grams and fractions of grams. Each weight is different for different styli. Take a look at your operation manual and adjust the weight. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 22, 2010 | Numark ttUSB Turntable
All records are skipping even though player seems to be working right and sounds ok....how do i fix this?
It is possible that your pick up arm is not adjusted to the corect weight on the record, or there is some vibration. Try increasing the weight of the pick up head by adjusting the counter balance at the back of the pick up arm
Dec 27, 2009 | Audio Players & Recorders
My brandnew Songwriter is not playing records properly. When a quarter is placed on the tone arm, it plays fine. Is there an adjustment I can make??? Marilyn
http://www.crosleyradio.com/Manuals/CR248_Manual.pdf
I didn't see the tone arm balance adjustment in the user manual, however that is what needs to be done. At the rear of item #39, on page 10, is there a dial with numbers from 0 to 4 or 5? If so, set the dial to "0" to see if the tone arm will "balance" (like a see saw) If not, the dial assembly (which is a weight) needs to be slid either forward or backwards to achieve balance. After balancing, turn the dial to a number higher than 0 to increase tracking force..keep increasing the tracking force until it stops skipping, but no more than necessairy. To much force causes wear/damage to albums. If there is no tracking force adjustment on the tone arm, I would suggest contacting Crosley @ http://www.crosleyradio.com/Support.aspx
Hope this helps.
Aug 18, 2009 | Crosley CR248 Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Electronics - Others Logo
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
