Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic z turns off when i push start button
Add garment light won't turn off.
  • 3 Answers
SOURCE: maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Posted on Apr 13, 2008
CMV9
  • 594 Answers
SOURCE: I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Posted on Apr 16, 2009
  • 240 Answers
SOURCE: Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Posted on Apr 26, 2009
  • 20 Answers
SOURCE: Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
Posted on May 22, 2009
frederiquema
  • 76 Answers
SOURCE: Mod 11046472501 Kenmore the power is on, but when
Have u tryed to "slam" the door shut?
Posted on Oct 26, 2009
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
How much it cost to fix maytag washer epic z After I push Power, My Maytag epic z front load washer is turning itself off as soon as I press the Start button!
Press the button on the far right next to the Off button and hold for 3 seconds. I think it's the "Cycle End Signal" button.
Dec 02, 2011 | Washing Machines
Maytag Epic Electric Dryer will not start, turns on and when you push the start button it gives me a series of beeps and then the lights by the different cycles blink, but will not turn on. Was working...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 17, 2011 | Maytag Dryers
MAYTAG EPIC X MHWZ600 When I press start the add garment light turns on and then about 45 seconds later it turns off. I HAVE TRIED UNPLUGGING IT BUT NOTHING IS WORKING. Sorry frustrated, but is it a...
all it's telling you is if you want you can add more clothes without restarting the wash all over again,all you have to do is hit pause and you can open the door,to put something else into the washer without any problems,i think you have 7 or 8 minutes before this stops when you first start the load,it might not do this on all cycles but if it comes up that's not an error code.
Feb 10, 2018 | Washing Machines
Lock out only certain cycles
Not enough items in tub, add a garment and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
