Question about Refrigerators
GE MONOGRAM ZIC36N RH Had Leakage. Called for repair. Were told that the drain area in the freezer section was stopped up, and not dripping into the tray beneath. Layer of ice had built up on freezer "floor", beneath basket. We totally defrosted, unclogged tube, flushed with hot water, confirmed it was now dripping into tray. Turned power back on to the Refrigerator. Freezer working OK, upper, refigerator section not cooling. (Light's on, etc. but temp is not cool!!
  • Cathy Blount Jun 20, 2009
    Dumb Question: Where are air vents?
    Hoping you will tell me where the air vents are located??
  • 583 Answers
Air vents to the refrigerator section must hve blocked.
also check for a longer time to see wether freezer also goes hot after sometime and stops cooling.if the freezer goes hot too,then its a defrost timer failure and you will hve to replace the timer.but if the freezer continous to work then its just a problem of clogged refrigerator section vents.cleaning up clogging should solve the problem.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 20, 2009
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
I have a GE monogram side by side refrigerator and water has started collecting in the "express chill" drawer at the bottom of the refrigerator side. It appears to be collecting in the "ceiling" of th
water into the fresh section or just on the floor around freezer or fresh food door. I also cannot take all credit for solutions in the area of refrigerators leaking water. Every person contributes their own experience so those that have should also be rewarded for their own efforts. I am pretty sure you are having a defrost by CouponDropDown">drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Mar 31, 2013 | GE Monogram Side by Side Refrigerator
Ge moogram Model# PSB42YSXSS The first time I went to this unit temp freezer was 12 but ref was 58 cleaned out condenser next morning Freezer 0 ref 37 week later fr is 40 ref58 water is leaking from evap...
Hey Rkraft,
i may have answered that question in the comment ya posted on the other Monogram
But now as i think about it how is the frost pattern on it is part of the evap coil covered in ICE (not frost) that could be a sign of a sealed system problem but only if part of the evap coil is iced up and the tube i spoke about on in that other comment isnt frozen
GENE
Oct 15, 2011 | GE Monogram Side by Side Refrigerator
I have a 2004 GE Monogram zisw420dmc refer. There are often small drips on the floor under the lower left and right corners of the freezer door. The fiberboard and stainless door cover have become damaged...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | GE Monogram Side by Side Refrigerator
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
Water leaking into refrigerator section from freezer
The drain trough is clogged under the coils behind the freezer wall and also there should be a "p" trap on the back that is connected to the drain tube running to the bottom. Remove trap by turning and pulling being careful not to break the neck. You should be able to blow any debris out. Good luck. Blow don't ****. lol
Feb 13, 2010 | GE Refrigerators
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Water in the freezer
Drain needs be clean, Easy to say but is some work to do.
Oct 14, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
