Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ultra fresh side by side ice maker stopped working. getting red flashing light 2 times in sequence
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: ultra fresh side by side
Hi and welcome to FixYa, I am Kelly
The LED flashing only 2 times in sequence means that the optics for the ice maker are blocked or defective.
Download this manual: http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf and perform the optics test On page 28 of the file if your refergerator was manufatured in 2002 or after. Otherwise use the test on page 26. Thee is a possibility that if the optics path is clear and it continues to flash 2 times that both emitter and receiver board will have to be replaced.
Just note that the activation of the door switch and check times are critical to get a good test result.
Should you require parts you can enter your model number on this page to see the diagrams:
http://www.searspartsdirect.com Enter the model number then choos model search.
Thanks for choosing FixYa,
Kelly
Posted on Jan 01, 2011
Red light blinking ice in maker and dont found pushtab on the left and the red light stop flashing
Which model do you have? Sounds like you have a optic issue but need more information. Also please include the position of the harvest fingers within the Ice maker. Need to know if they are resting in like 2 o'clock position. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 18, 2016 | Maytag 22.7 Cu. Ft. Side-by-Side...
Kelly
Jan 01, 2011 | Kenmore 53642 / 53644 Side by Side...
Ice maker stopped working, red light is flashing, however water is working? What is the problem, how do I fix?
For the red light try removing or replacing your filter.
The ice maker usually has a make ice bar about it inside the freezer. The down position is usually on.
Dec 02, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dgafeqrt
Oct 08, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker stopped working, red light is flashing. Water dispensor works fine. Filter is fine.
heatman101
yury
Oct 07, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Seee note on ice maker stopped working, blinking red light
heatman101
rtwywy
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer stopped working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Mar 22, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Red Light Flashing by Ice Maker on and Off switch
Red light flashing and NO ice. I used a hairdryer to hopefully clear the frozen waterline and it made 1-ONE row of ice and stopped and the red light still flashing. help!
Oct 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
934 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
