Question about Maytag Atlantis MAV6000 Top Load Washer
Washer will not fill at all
Maytag Atlantis will not fill with water at all. Had a power surge from electrical storm and now washer will not fill with water at all. Other functions seem to want to work but it will not fill with hot or cold water at all.
    Sergeant:
    Champion:
  • 266 Answers
Blown fuse,or board
Posted on Jun 21, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
196 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
