I have a Dell Laptop with Vista, and recently purchased a Hammacher-Schlemmer Slide Scanner and it worked very successfully for approximately 162 slides, performed in several sessions; then suddenly, when I went to boot up the scanner, the ArcSoft software gave a error message as follows: Problem signature: Problem Event Name: APPCRASH Application Name: PhotoImpression.exe Application Version: 6.1.8.125 Application Timestamp: 47df8de9 Fault Module Name: uThumbManager.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 465e6fdc Exception Code: c0000005 Exception Offset: 00001e7e OS Version: 6.0.6000.2.0.0.768.3 Locale ID: 1033 Additional Information 1: 9385 Additional Information 2: 3d6d882e14303860619e307b7eab25d8 Additional Information 3: 6224 Additional Information 4: 9de98536e81f3bafa4af0756ab72a1c0 Read our privacy statement: http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409 I've tried several times to unistall the Arcsoft and it ties up my computer. When I try again, I keep getting the message above. Ed Stadler E-mail: stadlermi@verizon.net
  • stadlermi Jun 20, 2009
    I don't understand the reply: "registory values may be failed"; I am downloading to my hard drive,so no printer is involved. Looking forward to your answer, Ed
    President:
  • 2,187 Answers
HI,
The error code that Windows shows up is caused by a number of things. It could be a driver issue, memory issue and some even the program. If this happens after doing the a number of scans, restarting the scanner software, your system may not have resources to allocate for new tasks. Try closing other applications and processes and have only the software running and see if it works. At times an update of the driver would work. You may want to do a disk clean up found in Vista's system tools, it will help you clean up your drive in case your system is having problems with discarding of data. If this does not work you may try to uninstall this via the control panel and add remove programs and select your program. Restart then re-insall it then restart again.
Posted on Jun 20, 2009
  • 3,230 Answers
This seems like some registory values may be failed, its better if you can try connecting tham in other computer... and please give me the result, so we can work on it.
Thanks
The projection piece only projects portions of the digits. What can I do to fix it so that all of the digits project appropriately?
I suppose you'd have have to mess around with the lens. If you go to hammacher. com, they can help you. This radio has a lifetime warranty, so it's said
Jul 06, 2014 | Hammacher Schlemmer The Projection Alarm...
My Hammacher Schlemmer Projection Alarm Clock and Weather Monitor will not project the outside temp. It only projects the inside temp. How do I change? Also, can't change the time zone.
No solution but to return it...very annoying product but yet I like the projected display, very sharp and bright. The replacement was much better, it loses connection with outside transmitter often..but occasionally we see the outside temp
Dec 28, 2013 | Hammacher Schlemmer The Projection Alarm...
Peaceful Progression Wake Up Clock manual Hammacher Schlemmer
go to the Hammacher Schlemmer web site (www.hammacher.com) and in the search box insert "peaceful progression wake up clock".
Just below the description of the clock there is a heading "instruction manual", click on this and download the instructions.
Jan 23, 2010 | Watches
I bought a used brian the brain game, and the intstuctions were gone. how can i get it to work
Put batteries into Brian, Hold down the reset button under the upper left corner of the keyboard, and at the same time, hold down the R button on the keyboard.
Jan 01, 2010 | Hammacher Schlemmer Brian The Brain
Where can I get a manual for Brian the Brain?
www.robotsandcomputers.com/robots/manuals/BrianTheBrain.pdf
Nov 19, 2009 | Hammacher Schlemmer Brian The Brain
I need the drivers for the hammacher schlemmer slide and negative to digital picture converter.
i am not sure but you might look at vupointsolutions.com downloads for FS-C1-VP
i thin 64 bit not thre tho
Jul 04, 2009 | Office Equipment & Supplies
Digital Photo Converter
al introducir una foto en la bandeja, en la pantalla se ven muchas
lineas, como si la foto estuviera en movimiento.
Tengo un convertidor digital Vupoint.
gracias, marilú
Apr 30, 2009 | Office Equipment & Supplies
120 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
