Question about Eforcity Charging Station for Nintendo Wii Remote Control
Wii remote is not responding and every time i press a button the lights flash, after the battery was fully charged. I put regular bateries and nothing, either.
  • 20 Answers
You might have to re sync the remote to the consol again open the front cover with the wii on press the red sync button then press the red button inside the batt compartment on the remote you will have to have reg batts in the remote to do this then put the rechagable pack back in this might help ive had to do this a couple times
Posted on Jan 30, 2010
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • Dec 06, 2011 | Nintendo Wii Console
    The control lights of my wii just keep flashing but the controls don't do nothing to the wii, I try new bateries and still don't work
    First, remove the battery cover for the Wii Remote
    Then open the small panel on the front of your Wii console
    While holding down the sync button on the controller, press the sync button located under the small panel on the console, wait a moment, your contoller should then be synced.
    Jul 22, 2011 | Nintendo Wii Remote Controller
    My wii remotes are fully charged but they dont turn on
    Do the LED's flash when a button is pressed?
    1. Check battery alignment.
    2. Try other batteries.
    3. Resync with the Wii via red button if can't access the Home page.
    Mar 17, 2010 | Nintendo Wii Remote Controller
    When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
    If you have more than one remote, you may have to "sync" the remotes to your Wii system.
    1. Open the battery cover on your remote and press the red "SYNC" button. The lights on the remote should begin flashing.
    2. Open the cover on SD Card slot on the console and press the "SYNC" button.
    3. The lights on the remote should stop flashing after a few seconds. Your remote is now ready for use.
    This process must be repeated for each new remote.
    Feb 09, 2010 | Nintendo Wii Console
    If you have multiple wii remotes, make sure the remote you are using is synced to your system. In case you are not sure how to do this:
    1. Open the battery cover on the remote and press the red "SYNC" button. The lights on the remote should begin flashing.
    2. Open the SD slot on the Wii system and press the "SYNC" button.
    3. Once the lights on the remote stop flashing, the process is complete and you should be able to use your remote.
    Remember, you have to go through this process with each new remote in order for it to work.
    Feb 09, 2010 | Video Game Consoles & Games
    My wii remotes wont pick up signal blue lights flash then just go back out again
    Hi, check the batter level and then try re-synching the remote's.
    Here's instructions for both:
    f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
    Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
    There are two ways to check the Wii Remote's battery levels:
    • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
      or
    • Use the HOME Menu to check battery level of each Wii Remote:
      1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
      2. Select the Wii Remote Settings option from the Home Menu.
      3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
    55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
    1. Press the Power button on the Wii console to turn it on.
    2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
    3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
    This procedure must be followed for each additional Wii Remote added to your system.
    I hope this helps
    Mike
    Jul 30, 2009 | Nintendo Video Game Consoles & Games
    Wii remotes will not stay on
    2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
    3. Remove the battery pack & install regular batteries.
    4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
    5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
    6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    7. Quickly remove the batteries and reinsert your Battery Pack.
    8. Return to Step 2 for each other remote.
    You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
    Dec 16, 2008 | Nintendo Wii Console
    Wii remote
    Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
    Hope this helps
    LesPix
    Feb 28, 2008 | Nintendo Wii Console
    Eforcity Charging Station   for Nintendo Wii Remote Control Logo
    312 people viewed this question
    Top Eforcity Video Game Consoles & Games Experts
    James Wishart
    Marvin
    Marvin
    Are you an Eforcity Video Game Console and Game Expert? Answer questions, earn points and help others
