Question about Maytag MGR5750 Gas Kitchen Range
My oven won't shut off
I had to turn it off at the circuit breaker. The know is turned to off. However the heating element on the bottom looks like there is something built up on it.
  • rmaazar May 11, 2010
    oven controller may be shorting out this is common where the stovetop is used to cook alot of greasy foods
aborcass
  • 2651 Answers
SOURCE: RCA oven bottom heating element burned up
youd be better to leave the old elemnt in tillits replaced, the wire leading to the elemnt is ALWAYS live, even when not on there is ALWAYS power to the elemnt wire
Posted on Dec 02, 2008
  • 60 Answers
SOURCE: bottom oven does not heat up, top oven works
the most common problem for your description is that your bottom ignitor is not working properly just because the ignitor glows doesnt mean your ignitor is working it has to draw 3 amps or more to ignite the bottom burner part number for the ignitor is 12400035 let me know how you make out
Posted on Sep 12, 2007
jsrock516
  • 5911 Answers
SOURCE: bottom element will not turn off
Your BAKE element relay on the Electronic Oven Control (EOC) Board is shorted.  I have experienced this problem before.  The board is not serviceable and (unfornately) you will have to replace it.  The board can run anywhere from $100 to $200 for a new one.  Slightly less for a refurbished one.  Prices will also vary depending on source.  This is a repair you can do yourself if you choose to do so.  If you can provide me with your model number (located inside the lower door panel), I can do some research to get a part number and price for you.  Let me know.  I hope this is helpful.
Posted on Oct 31, 2007
SOURCE: Gemini MER6769BAW Range/Dual Ovens
depending on type of unit. most of the time they are very easy to change out.. look at element locate two screws. go shut off breaker to oven.. make sure its has no power. after removing screws element should come out fairly easy.. make sure not to let wires fall back inside unit. if so not to worry. just pull unit out from wall and remove back panel. push wire back through. hope this helps
Posted on May 15, 2008
vanni7
  • 163 Answers
SOURCE: Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Posted on Jan 04, 2009
How to repair an electric oven that won't shut off?
call an electrician to test the switches for faults or the circuits for a problem
possible a loose active wire touching where it should not be from rotting insulation or loose screws
Sep 17, 2016 | GE Profile JDP47 Electric Kitchen Range
Will just replacing the oven element fix my Kenmore model 911.955879range oven? It sparked, broke in two and a white flame continued going around the element, wouldn't stop I had to shut breaker off.
Hello Jennifer;
My name is peter. I am a retired field service appliance technician.
Good for you - turning off the breaker.
You have a older oven. Usually there is a spark or crack in the oven element. In your case the element was so embrittled it broke into 2 pieces.
Before you use the top range burners to be on the safe side you need to disconnect the oven element. You may have damaged the oven control board to where it is locked into power for the oven.
25713262-01ium3bsyoj5ql4fhv4kpwvp-4-0.jpg 1.) Remove the bottom drawer to reduce weight.
2.) Put a rug on the floor in front of the oven, so when you pull the oven out it does not scratch the floor.
3.) Pull the oven out so you can get behind it.
4.) Unplug the unit.
5.) Remove the back bottom cover.
6.) Disconnect the heating element and remove from oven.
7.) Rap the two loose element connections in the back with electrical tape.
8.) Follow the element loose connection to the control board at the top. Disconnect at the oven control board.
9.) Inspect the loose wiring from the control board to the heating element for burns or melting.
10.) Plug the oven back in and turn on the range burners.
The part number for the oven element is WB44T10014. Sears wants about $95.00 for this part. Search the internet for this part number and get it for about $28.00.
Your oven control board may have become damaged. Recently I replace one for a friend. Sears wanted $256.00. I got a remanufactured board over the internet for $30.00.
Get back to me and let me know what is going on.
May 25, 2015 | Kitchen Ranges
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
Oven will not shut off
Good Morning Friend,
I understand your Frigidaire oven will not turn off. I also see that when you turn it off, the blower and heating element, stay on. The blower will stay on to help cool down the oven, but the heating element should turn off. I see that you have to turn your oven off at the circuit breaker. I suggest contacting your local authorized dealer for further assistance. They will be able to diagnose your appliance and determine why your oven will not turn off. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Ovens
Oven will not turn off
-Best Regards-
WP
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
JBP65G GE range oven won't shut off
Electric Ranges have circuit boards that control the power to each burner or element. Circuit board could be faulty. I would not mess with electricity unless you know what you are doing. Call a certified repair specialist or the manufacturer if under warranty. Good Luck
Jan 31, 2012 | GE Kitchen Ranges
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
Bottom element will not turn off
Oct 31, 2007 | Kenmore 95592 / 95594 / 95595 / 95599...
Maytag MGR5750 Gas Kitchen Range Logo
210 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
