Question about Compaq Armada E500 Notebook
Compaq Armada e500 won?t recognize the cd drive
I just picked up a Compaq Armada e500 in a yard sale everything works except it won’t recognize the cd drive any suggestions?
    Novelist:
    Scholar:
  • 117 Answers
Simple things first: Assuming the CD drive is removable, remove it from the laptop then re-iinsert it making sure it's pushed home properly so that the connectors seat properly.
If, again, the drive is in a bay (i.e. it's removable) then it may be the connectors are worn/damaged. If it's the drive connector then it may be repairable or you might pick up another drive, perhaps on eBay. It may also be that the drive has simply given up the ghost - so back to eBay :) If the connectors on the laptop have got damaged then you're looking at dismantling the laptop to repair/replace them, if that's possible.
If it's an external drive then the advice is very similar - check out the connectors first. If they look OK then you probably have to suspect the drive itself.
For either type of drive, there is always the small chance that the IDE controller channel on the motherboard has died - I have seen this happen in rare cases. Your options then are a bit limited. IIRC, that PC has no USB2 and even if it did, it wouldn't boot from a USB CD. You can get a PCMCIA interface card (now called simply PC interface) for an external CD. Depending on the card-drive interface, you might be able to boot from that.
If you need to install software onto the machine & have another (desktop) PC to hand: remove the disc from the E500, get a 2 1/2 to 3 1/2" disc adapter & temporarily attach the drive to the desktop as a secondary (i.e. not boot) disc. You can then load software onto the drive although you can't do a Windows install that way. If the machine already has an old version of windows on it, you can copy for example, the XP install files onto the drive, put it back in the machine & run an upgrade. Not the most desirable result but may be OK.
Posted on Nov 03, 2007
How to reformat hard drive on compaq armada e500
Move your Document files to the other drive if you have more than one drive on you system or get external drive and move your important documents to this drive.
Get a bootable OS CD and put it in your CD/DVD-ROM drive, reboot the system. The system will try boot from the CD confirm the press any key to boot from the CD by pressing any key at this point. If you did not get the message on time before it disappears, repeat the reboot process again. Once the system boots from the CD, follow the on screen step-by-step guide.
May 30, 2010 | Compaq Armada E500 (230659-001) 30 GB Hard...
My computer is asking for a specific command when trying to install a fix it utilities program. it reads "Your CD-ROM drive is X:"
in this case you have to manually select the cd -drive ...so ...browse and select the drive where the installer cd is ....if you are using an image with a virtual cd drive ( like daemon ) select the drive where the files run ...cause probably it doesn't recognize the path
Sep 16, 2009 | Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
Non-system disk or disk error
Is you cd-rom drive shot - are you trying to boot up your computer through an xp or windows cd? If it is, it's not going to recognize and boot up. You'd be best getting a new drive - look around for someone with a Compaq Evo 800cp. They have the same exact cd-rom drive. Here are your compatible cd-rom devices:
TEAC DW-224E-A
or a Compaq DVD-ROM DRN-8080B
otherwise try a HP SD-C2612. I have these three drives. They all work really well.
Jul 01, 2008 | Compaq Armada E500 Notebook
Compaq armada e500
The key for bios is F10 just press during compag loading screen or if dat doesnt work immeditely after. I found this out by trying all of them in sequence to see which one worked
Jun 09, 2008 | Compaq Armada E500 Notebook
My compaq Armada E500 wont come on
Replace hdd couse the pc dont recognize hdd..First go to the bios and load optimal default or optimized default and pres F10 and restart
If it wont work just buy NEW HDD
Oct 19, 2007 | Compaq Armada E500 Notebook
Computers? Easy??
If you are trying to boot with a cd then you need to have your cd rom drive as the first boot option, which is in the bios (f2 or DEL on boot up). I you have your own windows CD, then you can format the hard drive using the cd.
Nov 21, 2006 | Compaq Armada E500 15 in. Flat Panel LCD...
Compaq Armada E500 Notebook Logo
664 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
