Gateway SX2110G-UW308 Small Form Factor Desktop PC with AMD E1-1200 Logo
A
Anonymous Posted on Apr 27, 2014
Cannot get online
Downloaded belkin wireless disk but unable find avail networks or strength bars to click on..error 651???
1 Related Answer
Anonymous
  • 170 Answers
  • Posted on Dec 28, 2008
SOURCE: Unable to find network adapter.
You may have to call acer and order restore di$k,
After downloading the disk, my computer is unable to connect to the Belkin router.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Having an issue getting my laptop connected to the internet. The wireless networks appear and it shows that i am connected to the linksys, however i get a dns server issue when i try to go online. It shows...
I see that your having issues with you wireless connection, you mentioned that it is an old model Router that has a B wireless signal and that you are connected to the Router but you get an Error about the DNS having issues, try checking your Routers Network Key, make sure that your Network Key in the Laptop and Router are the same.
- to get in your Belkin Router you must type in your Default Gateway on you browser ex. IE, Firefox 192.168.2.1 then press enter after typing your Belkin's Default Gateway you should get a window prompting you for a user name and password
your user name would be admin and the password leave it blank then press enter unless you have changed the user name and password setting of your Belkin.
- check under wireless and security to see your Network Key/Security Key and copy what you have in you router and use it on your laptops network security to be able to access internet from your Belkin Router.
Hope this helps.
I have a problem with my NETGEAR WNA1100 Wireless-N 150 USB Adapter. I use it with my desktop PC and a Belkin 802.11g router placed in another room. As soon as I installed it, everything seemed to work...
Your Issue can be Solved by assigning DNS address on your Computer.
>First of all change the Security on the Belkin Router to WEP Mode.
--- Remove Preferred Networks From your Computer.
- Right Click on wireless Network Connection > Properties > Select Wireless Networks tab > Remove your network From Preferred Networks Box.
--- Associate with your wireless Network.
- Right Click on wireless Network Connection > View Available Wireless Networks > Select your network > Click connect
---> Check if you are able to go online.
--- If Not Try Assigning DNS Addresses For your Wireless Network
- Right Click on Wireless Network Connection > Properties > Under this connection uses the Following Items. > Double Click on Internet Protocol (TCP/IP).
- Select Use the Following DNS Server Addresses:
- Preferred DNS Server: 4.2.2.1
- Alternate DNS Server: 4.2.2.2
- Click OK & OK again
- Now Check if you are able to go online if still No go Check if you can go online on any other wireless Com or Device using the Belkin Router If Yes it Might Be an Issue with your Adapter or there Might Be an Antivirus Installed on your com Try Disabling it.
- If this doesn't work Please do get Back to us we will be happy to Help you out... :)
I have a new Belkin Play router and when I watch a video online (like a you tube video) it pops up and says that my Belkin router password may have changed. It then asks me to re-enter my password and then...
= The Belkin Router Utility Might Not have Been Installed Properly.
> To Get Rid of this Issue 1st of all Disable or Uninstall Belkin Router Utility.
- Goto Start > Control Panel > Uninstall Programs
- Select Belkin Router Manager Utility & Uninstall It.
> Now you Have to Remove preferred Networks & Join the wireless Network.
Steps to Remove Preferred Network & Joining the Network
- Windows XP
- Goto Start > Control Panel > Network Connections > Right Click on Wireless Network Connection > Click on Properties > Select Wireless Networks Tab > Under Preferred Networks Box > Select your Wireless Network Name & Click on Remove Button. Close the window
- Right Click on Wireless Network Connection & Click on View Available wireless Networks.
- Wireless Network Connection window will appear. Select the network you wish to connect and click Connect. It will ask you For a Network Key Type in your Password.
> Windows Vista & Windows 7
- Go to Control Panel > Network and Sharing Center > Click on Manage wireless networks Right click on your wireless Network > Click on Remove Network .
> Connecting to a Wireless Network.
- Goto Network & Sharing Center Click Connect to
- Select your wireless network & click Connect
- It will ask you For a Security Key Type in your Password.
( If you are unable to go online you can try power cycling the router for about 15 seconds. If Even Power cycling doesn't work that means you have to disable WPS option on the Belkin router)
Inttalled belkin wireless adaptor, says strength is good, but not valid ip
the work of a belkin adapter is to receive the wireless signal in and around the adapter when pluged into computer
if ur able to see the wireless network then ur adapter is working fine
check the ip as
start>control panel>network connection>rite click on wireless network>click properties>choose internet protocol tcp/ip (highlight it and click on properties) then "obtain ip address has to be checked"
then cllick OK and try going online --- u must access the internet
Cannot connect to my laptop. internet i working on my desktop computer. i have belkin wireless G router. i have unplugged the router but still unable to connect.
Once its connected you will have the blue light in the belkin router
1.Turn on the wireless switch in your laptop
2.Click on start menu--->control panel--->Network and internet--->Network and sharing
3. In the right hand side click on "Change adapter settings or Manage network connections"
4.You will see the wireless network connection
5.Right click on wireless network connection and click on Connect/Disconnect
6.you will be able to see the network name,try to connect it.
7.it will be connecting and then connected
8.try to able to go online in the laptop
Regards,
Ayyasam
3helpful
2answers
Lost cd for belkin ni wireless usb adapter
This link can be helpful to you where all the Belkin's N1 Wireless USB Adapter - Software and Drivers are listed for downloads.
http://en-us-support.belkin.com/app/answers/detail/a_id/540
Was working ok, now cannot get online using belkin modem-router. Says I am connected to my network, "signal strength excellent" but no wireless connection. Using the Belkin Modem router I am unable to...
please try to reset your router.
on the back of the router there is a little hole where you can insert a pen or a paperclip. hold it pressed in for 30 seconds and then release.
wait 10 minutes and try to connect to internett again (after connecting to the wireless net ofc)
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
