Question about Boating
140hp johnson seahorse tilt will raise the motor
140hp johnson seahorse tilt will raise the motor but it goes back down on its own no visable leaks on the out side need info on how to repair or a site where i can get info thanks
  • Anonymous Mar 20, 2014
    Need any info about this 12 gauge break front thanks
  • Anonymous Mar 24, 2014
    want to rebuild the engine
  • 77 Answers
It needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
Posted on Jun 21, 2009
My johnson 50 when in the up position it slowy goes down and there no oil leaks ps how much tilt fluid should be in it tilt cheers michael
Have a bad check valve somewhere in the system allowing pressure to bleed backwards through the system, should be able to hear it when the bucket is up in the air turn off the tractor and listen closely to the lines for a slight whining sound from the fluid leaking when it should be sealed
Oct 11, 2016 | Sierra Johnson/Evinrude Tilt and Trim Pump...
1996 70 hp johnson outboard ,,need to know why the motor rise up when I put it in reverse and give a little speed to back up, and when I let off the speed the motor goes back down.
In reverse, the propellor is pulling the motor away from the boat, this is the same direction as the motion you get when you tilt the motor up for transport. Check the motor mount, especially the motor tilt mechanism to make sure nothing is excessively worn, bent or loose. Maybe the latch that's supposed to hold the motor in the run position isn't working right - that could be bad news if it lets the motor drop down while the boat is on the trailer.
Jun 26, 2015 | Boating
1996 70 hp johnson outboard, when put in reverse the motor lifts up when given a little speed and goes back down when you let off
If it does not have Power tilt, the tilt lever is either not in the run position or the mechanism is bound up. Look for a hook shaped that engages your tilt rod (the rod that sets the tilt angle in the 4 or 5 holes in your transom bracket. BTW no rod, no reverse lock.
What year is my Johnson "seahorse" serial# J252 668, model# CD-22M
the SEA HORSE models were made late 50's thru early 60's
Apr 02, 2014 | Boating
Johnson seahorse 6 hp
Check to see that you have proper air flow through the cowlling. It sounds like it's not getting enough air to the breather.
Dec 05, 2013 | Boating
77 70hp Johnson with no power tilt-trim. Can't raise with tilt-run lever
screwdriver lift locking arm on lock down rod and lift motor
Mar 28, 2013 | Boating
How to raise manual tilt johnson (no tilt trim)
on the right side of the motor there is a lever that says tilt on it pull it up unlocks motor grab the top of motor and pull with all your mite
Mar 25, 2013 | Boating
1978 johnson 25 hp
Hi, make sure you are using a genuine pin and if so check the back of the prop where the pin sits for wear, regards Phil.
Jun 11, 2012 | Boating
Where do i put in hydraulic fluid in a johnson 225 boat motor
if its an outboard you will see a reservoir near the cylinder on back, be careful and set the shallow drive lever so the weight is off the hydros when you open it, there can be up to 3000psi if it has weight/pressure on it
once added you have to blead air bubbles, go up then down at least 10 times
also a boat parts store(phone book) may be able to help you
Jan 02, 2009 | Plumbing
Boating Logo
363 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
