Question about GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC Side by Side Refrigerator
Evaporator Coils freezing.
I have a GE side by side refrig Model GSH25KGPA. The evaporator coils are freezing up. How would i know if the circuit board is bad, or the thermostat, or the heater? I have read another answer that describes checking the blue and orange wire of the circuit board and J1-4 and J1-5 of the circuit board. I have the circuit board open but I'm not sure where the above connections are. Thanks for your help.
  • 2 more comments
  • 1alembic Jun 20, 2009
    Vic, thanks for the response. When you say "continuity" do you mean no resistance? And is the bi-metal switch also the thermostat? thanks. I'll check both tomorrow and leave a response as to what I find. thanks again.
    Kevin
  • 1alembic Jun 21, 2009
    Thanks again. I just took the heater out and tested it. It does have continuity. I also tested the heater with this method of using Alligator clips to force the heater on and it did heat up while connected in the freezer (http://fixitnow.com/wp/2008/11/04/how-to...). Is there some reason it is not coming on automatically when I'm not using the alligator clips? Thanks for all the help.
  • 1alembic Jul 12, 2009
    Vic,
    I tested the bi-metal switch and it did have continuity when cold and when warm. So I replaced the mother board. When I replaced the mother board I also dethawed all the coils in the back wall. However, after about 2 or 3 weeks the evaporator coils were completely frozen again. Do you have any other suggestions or ideas about what may be wrong. could it be a problem with the temperature sensors?
    Thanks,
    Kevin
  • 1alembic Jul 13, 2009
    Thanks Vic. I'll replace the bi-metal switch and see if that makes a difference. If not, I'll post again in a few weeks.
    thanks.
    President:
  • 1,136 Answers
Hi, The most common problem is the defrost heater. It is attached to the bottom of the evaporator coil in a bracket.
If you have a meter, you can remove the element from the coil and take the two wires off. Checck the post on the element that the wirea attach to for continuity. If the element is good, it will have continuity to it. If the element is ok, check continuity on the bi-metal switch attatched to the top of the evaporator coils. It too must have continuity to be ok and it needs to be tested while still cold.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
  • 2 more comments
  • Victor
    Victor Jun 21, 2009
    The bi - metal is a thermostat. If there is continuity, there is a closed circuit so the electricity can flow through the switch. If the switxh is open, the electricty can not flow though the switch.
  • Victor
    Victor Jun 21, 2009
    The other parts to the defrost cycle are the bi-metal switch and the mother board. The bi-metal switch must have continuity also WHILE it is cold!
  • Victor
    Victor Jul 12, 2009
    Kevin, If the bi-metal is the only thing that you have not changed, I would change it. It could be intermitant. If not adefrost problem, the only other reason the coils should frost up is if the evaporator fan motor is not working. The i-metal switch is a 2 fold switch on this model. It also lets the fan motor know when it is cold enough to run.
    If the temperature switch was bad, the refigerator would either warm up or start freezing even in the fresh food section.
    I believe they have changed the design of the defrost heater for this model as well. They have changed it to a double heater system.
    Vic
  • Victor
    Victor Jul 13, 2009
    Ok, You might want to ask your parts store about the bouble element upgrade as well. Ask if you model needs the change.
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My GE PTS25LHSARBB has developed a problem with holding temps
have you checked the evaporator coil for icing up,it sounds like after you unplug it it defrosts and the evaporator deices,this could be caused by dirty evaporator and condenser coils or warm air getting around door seals condensing on the evaporator coils and freezing and blocking cold air flow,if this is the case,then check defrost heater circuit for proper operation
Feb 03, 2010 | Refrigerators
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
What turns on the evaporator fan? I have a 5 year old GE profile bottom freezer fridge. I have discovered that the defrost timer is faulty. The defrost heater works and the evaporator coils frost up ok...
The main control board is probably the problem . Part number WR55X10656 . This board controls the operation of the fan motors and everything else on the refrig . This is also the " defrost timer " . However , the coils frosting up , is probably because the fan motor is not pulling air across them . Not because of a faulty " defrost timer " . This board is located on the back of the refrig , behind an 8"X10" panel . Usually a resistor burns out relating to the fan motor operation . Cannot replace the resistor , only the board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Apr 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC Side by Side Refrigerator Logo
340 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
