Question about Seagate DB35 (ST3250823ACE) 250 GB Hard Drive
Need cable, st3250823ace to G5 Mac, power and data cable
Need both cables to connect db35 seagate to my older Mac G5
  • Anonymous Mar 28, 2014
    need driver for mi Mac
I fixed it by getting a reply back from another web site for FREE. Thanks
Posted on Jun 21, 2009
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Can i replace 80 gb hd with 500 gb harddrive?
Of course. Get a transfer cable to move the 80 g data to the 500g then remove the 80 gig and plug the cable from the 80 g into the 500g.
Jun 29, 2012 | Apple Power Mac G5 Desktop
I need the installation book to install it.
The power connector (Molex) has a red wire (one of four) - the data wire has a red stripe on one side - the red stripes go toward each other. If you have a 80 conductor data ribbonn cable, this is for "Cable Select" position in the shorting plug. If yours is 40 conductor, you are NOT cable select. The Master or '0' drive goes at the end of the cable while a slave or '1' drive attached to the plug close to the end plug. The other plug of course goes to the mother board. Look for a small '1' on the motherboard (red srtripe). Use either Cable Select (if appropriate) or Master (if appropriate) or Slave (if appropriate) when selecting the shorting pins on the back of the device.
For your info, the little connector you will find inside adjacent the Molex is called a Mini Molex.
The Master is where the device "C" should reside (and have your operating system). All other drive designations will be set by your BIOS.
If you need more help, go to www.seagate.com/support and look up your drive for complete instructions. I think they have downloadable "tools' there to help you as well.
I hope this information helps you ... Thanks for your quesiton @ FixYa.com
Feb 14, 2012 | Seagate DB35 ST3160215ACE - 160GB -...
What are the correct jumper settings for my hard drive in an e-machine T-6520 with windows home ed. XP2005
cooperbill78 these are the jumper settings for a Seagate Barracuda ATA harddrive,
http://www.seagate.com/images/support/en/us/u5_family_1.gif
As you can see the jumper should be on Pins 7 and 8.
Make sure the harddrive is plugged into the END of the flat ribbon data cable.
Pin 1 goes toward the power connection.
Some flat ribbon data cable's connectors have a Locating Lug on one side. A square protrusion, or two ribs.
This lug lines up with a cutout in the circuit board on the back of the harddrive.
If no Locating Lug is present, and/or no Locating Notch in the harddrive, make sure Pin 1 is towards the power connection on the harddrive.
On one side of the flat ribbon data cable is a faint red stripe. (Sometimes hard to see)
This red stripe is on the same side as Pin 1.
When installing the flat ribbon data cable, ensure that the red stripe on the cable, faces the power connection on the harddrive.
For further questions please post in a Comment.
Regards,
joecoolvette
Jun 12, 2011 | Seagate Barracuda 7200.7 200 GB Hard Drive
How to install an internal hard drive (1.5 tb) on a ppc g5
there are actually extra spaces for internal drives with the proper connectors for the ribbon cable and the power cable.
Just open the side of the G5, and double check your connectors prior to purchase to be sure you get the proper type. You can connect it to the available connectors on the existing ribbon and power cable... Then boot it up and simply do a disk utilities mount and format of your drive and you're good to go.
Nov 19, 2009 | Apple PowerPC G5 Mac Desktop
Lost connect to all servers, internet and email
Create a new user account on your machine and use it. Your account might have gone bad.
Jul 02, 2009 | Apple Power Mac G5 Desktop
How do I move the data from broken DVD Recorder HD, to my PC?
you can take the side of your computer, and plug this into your computer, you might need the sata cable but will work a treat :)
many thanks
Feb 15, 2009 | Seagate DB35 ST3500841ACE 500 GB IDE Hard...
HDD Connection
Hi, you'll need one of these: http://www.csncables.com/Cables-to-Go-1018X-GY1352.html (Data cable).
& one of these:
http://www.mwave.com/mwave/Skusearch_v2.asp?scriteria=BA00307 (Power cable IDE 4-pin to SATA drive). Unless your current power supply has a SATA power connector.
Open your manual to the top of page 1-24. SATA data cables connect one way only. It does not take much to break the ( L ) shape end of either the data cable or the SATA power cable.
(All SATA drives are seen a master drives). When in your bios choose the correct drive under Boot > Boot order.
Need more info, just ask.
Mike
Sep 09, 2008 | ASUS K8V-MX Motherboard
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate DB35 (ST3250823ACE) 250 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
