Question about Motorola Cell Phones
Need online manual for motorola h371 bluetooth headset
I need to know how long it takes to fully charge the Motorola h371 blue tooth headset, plus the manual for other things
PyroMan6x9x9
  • 150 Answers
SOURCE: motorola blue tooth
No problem, First you need to turn blue tooth on in your phone, menu>settings>bluetooth(sometimes it's connection>enable bluetooth. Then you have to tell your phone to search for a device I think that's under handsfree in the bluetooth menu. To put tell your headset to look for the phone make sure it's off. Then press and hold the power key until it starts flashing repeatedly, (if your headset has a flip mic you will have to flip it open as you are holding power) The trick is putting both the phone and headet into pairing at the same time. the phone should find the headet, you need select and it will ask you for a pass code, the pass code is 0000 . Hit connect and you are good to go. Good luck, if you need more details let me know what model headset and what model RZR. (V3, V3M,V3XX) L8R
Posted on Sep 17, 2007
  • 35 Answers
SOURCE: motorola blue tooth pin code
Yes there is a universal code. It is 0000. That is four zeros.
Hope this helps :)
Posted on Oct 26, 2007
  • 316 Answers
SOURCE: motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Posted on Nov 03, 2007
MonsterG
  • 52 Answers
SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Posted on Feb 11, 2008
SOURCE: motorola razor asking for passkey to bond with bluetooth headset
default pin for most bluetooth is 0000
Posted on Nov 20, 2008
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I'm trying to pair a Motorola H371 to a Blackberry Bold 9650. I can't find the password for the pairing. Do you know what it is?
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Sep 29, 2010 | Motorola Mobility H371 Bluetooth Headset
Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
May 23, 2010 | Motorola Mobility H500 Wireless Headset
Need the code to pair my blue tooth motorola
Try using 0000 as it's the basic code for every bluetooth unless manually change. That is the factory default.
Dec 31, 2009 | Motorola Mobility HS850 Consumer Headset
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Motorola H371
Guys, try to put in the number 0 four times, and that should work. I did it on my bluetooth and it worked. Good Luck !!
Dec 12, 2007 | LG KU990 Viewty
Discoverable Mode
Here is the on-line manual: http://www.motorola.com/mdirect/demos/how2_h3/main.html -First off make sure the headset charges for at least two hours. Also make sure theindicator light turns on indicating charging is occurring. -After the charge is complete you will need to refer to your phones manual to pair the headset to the phone. The discover mode is a mode the phone goes into not the headset. I don't have an LG8600 nor can I find a manual on-line so I can't help you with that part. If you still need assistance let us know and please don't forget to rate the posting.
Jan 23, 2007 | Motorola Mobility H3 Bluetooth Headset,...
Cell Phones Logo
1,784 people viewed this question
Top Motorola Cell Phones Experts
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
