Question about Toshiba TS-L632 DVD±RW Burner
My DVD/RW is not read anything!! I'm running XPwith SP3 , I tried to reinstall the driver of CD/DVD but still the same problem, only I can run the CD of Windows XP from the booting screen. If I open the Operating system and insert [ CD or DVD ] I got 0 bytes!! and I can't open it, But, when I restart the computer and Insert the CD of Windows XP it's working and I can do a format, but if I insetr a DVD of Windows Vista or Windows 7 then the DVD CD not working at all. Please HELP !!
  • 1 more comment
  • al_rujibi Jun 28, 2009
    i have download and run this update but i got this message [[ The Frimeware is not compatible with the selected drive. Contact your system manufacturer for information on frimware
    updates available for this drive. ]] and i try to download frimware from Toshiba web site and i got this message too [[ ///ODD Firmware Update Utility Ver2.59A ]] & [[ Available target is not found. ]] ... any help?
    Sergeant:
  • 220 Answers
Try updating your firmware http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?soid=2024958
Hope it helps
Posted on Jun 20, 2009
Dell dvd bad CD OK
please check what type of dive it is cdrw/dvdr or only COD -rom...if only cd rom it will not read DVD's...go to run ...then type msinfo32 then components finally under check the type of CD/DVD drive installed...if everything is ok...reinstall the chipset drivers....thanks...also if u can check in BIOS if the drive is getting detected.
Feb 13, 2012 | Computers & Internet
I have octo edge samsung dvd writer.. it reads dvd's fine no problem.. but it burns dvd or cd. it stops burning between 10% to 15%. and shows input/output error.. then the DVD gets wasted.. Is There a...
make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the drivers could be on it
your drivers may have been corrupted or you might have a virus run your antivrus program
hope this helps
Jun 18, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I still can not get the Laptop running Xp Pro sp3 to see the CDRW/dvd combo drive. I followed all of the previous instructions but when I get to the Place where I'm supposed to delete Upper Filters. There...
make sure that the cdrw-dvd rom is getting enough power test all leads that are attached to the cd-dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Apr 01, 2011 | Dell (8W007-A01) for Latitude, Inspiron...
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My DVD+/-RW with labelflash recently stopped reading DVDs, CDs, and select data discs. Some discs read instantly without a hitch others aren't even detected. There is no disc error message. They are either...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 03, 2011 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
After burning a dvd the drive can not read the dvd other drives does read the dvd. using windows xp sp3
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 13, 2010 | Lite On (SHW-1635S) DVD RW Dual Layer...
My cd-rom can't read CD-R??!
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Nov 25, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
My cd-rw can not read any cd while it has no problem with reading dvd.
how does a CD_RW drive read a dvd anyways unless it is a CD-RW DVD-ROM drive and in that case you should try reinstalling the device driver
Sep 06, 2010 | Panasonic Matshita- | CW-8124-B | USB 2.0...
My DVD/CDRW only reads commercial dvds
My hl-dt-st cdrw/dvd gcc4244 ata device cannot write on DVD-rw imation cd why. How to resolve this problem
Dec 23, 2008 | Teac (DW224E/S) CD-RW/DVD-ROM (Combo)...
How to Install Sony DRU-710A DVD-RW
Cd/dvd drives don't actually require a driver to run. They use "class filter drivers" which are supplied by a burning program like Nero or NTI. These "class filter drivers" only add functionality to the drive. Windows just uses a generic driver "MSCDEX" to run them.
A couple of things to try:
Uninstall the drive. Open Device Manager, click on the + sign next to CD/DVD ROM drives, right click on the drive and select uninstall. Exit and restart your system. When windows loads, it will recognise a hardware change, and will ask if you want to install. Before you click anything, insert the disc that came with the drive (if you have one). This should then install, if not, let windows search. If windows can't find anything, select "I will choose the driver manually" and look for your drive in the list.
Another thing to do, is download the most current Chipset drivers for your motherboard (which I would recommend anyway, even if the above worked).
Update the Firmware version and the internal drivers for your drive. These can be found here: http://sony.storagesupport.com/product/112#drivers
Also, update windows to the latest Service Pack (SP3 for XP and SP1 for Vista) if you haven't got them already.
If you have Vista, did you recently update to SP1 via Windows Update? If the answer is yes, please let me know.
Hope these solve your problem
Regards,
Tim
Dec 09, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Toshiba TS-L632 DVD±RW Burner Logo
507 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
