Question about Dell 966 All-In-One InkJet Printer
My dell photo 966 printer has a broken drive belt tensioner pulley. is there a disassembly guide and a parts diagram available?
Posted on Jan 15, 2011
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
Canon Pixma Pro9000 won't transport the print head carrier. You can slide it freely by hand from one end of the case to the other. It does seem to lift and lower by itself. When you turn the printer on,...
Check the print head drive belt. It should go around a drive pulley on one side of the printer and a spring-loaded tension pulley on the other side. Verify that the tension pulley is keeping the belt from slipping. Also, if you can see the drive pulley with the cover closed ( you may need to shine a light on it), watch to see if it is turning during a print cycle.
Jul 03, 2017 | Canon PIXMA Pro9000 InkJet Photo Printer
Serpintine belt diagram
what engine? Please rate if it helps
3.L v6
snorkelbobby_26.gif Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner 6 10344 Generator pulley
2.0L Zetec 4 cyl with A/C
snorkelbobby_27.gif Item Part Number Description 1 10344 Generator pulley 2 19A216 Belt idler pulley 3 3A733 Power steering pump pulley 4 6C301 Drive belt 5 2E884 A/C clutch pulley 6 6B320 Crankshaft pulley 7 8509 Water pump pulley 8 6A228 Drive belt tensioner
Jan 12, 2011 | 2002 Ford Escape
Carriage belt is off, loose when on
Carriage belts are tensioned inside the machine on one of the idler pulleys. A belt that came off usually indicates there is a lubrication issue - one of the pulleys won't turn easy or the print head is binding on the slide shaft (Extremely common). The belt may have stretched (though unlikely) You may be able buy the belts from SDP-si.com in the US. This is just one of the sources. Try a printer repair shop.
Mar 20, 2010 | Dell 966 All-In-One InkJet Printer
Dell Photo 966 AIO won't print after trying to download Adobe 9
You need to restore your computer to a date previous to your Adobe 9 install. Click the following:
Start-Programs-Accessories-System Tools-System Restore. Choose an available date prior to the date you installed the problematic software.
Nov 07, 2009 | Dell 966 All-In-One InkJet Printer
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
Broken Belt
check the belt path, there is a tensioner somewhere in there that will tighten the belt.
Aug 01, 2009 | Dell 966 All-In-One InkJet Printer
Dell 966 printer - missing white wheel & spring from belt tension
COMPUTER REPAIR SHOPPE
1751 Lower Roswell Rd
Marietta, GA 30068
ph :770-578-1312
Jul 22, 2009 | Dell Photo 964 All-In-One InkJet Printer
DELL AIO 966 Carrier belt detached from printer
The belt goes through the back of the ink carrier.
There is a spring somewhere that keeps tension on the belt with the white roller.
The belt itself hooks into the frame of the machine.
Jun 21, 2009 | Dell 966 All-In-One InkJet Printer
The drive belt on the inkjet carriage came off it's wheels.
You'll have to disassemble the printer, remove the bottom of the printer and turn it upside down to where the belt and underside of the ink carriage (where ink comes out) is exposed. Take the closest loop of the belt and insert it around the plastic piece attached to the carriage [see image]. Then reassemble the printer. If you aren't good at taking things apart and re-assembling them you may have a hard time with this. Also, you may severely damage your printer if you break something mechanical or electronic in the process. Don't blame me.ff8bdfe.jpg
Mar 27, 2009 | Dell 966 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
1,305 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
