Question about Bosch 11236VS Rotary Hammer
BIT FALLS OUT/ WON'T TURN
BIT WILL NOT LOCK IN AND DRILL WILL NOT ROTATE
  • Dean
    Dean May 11, 2010
    what type of drill bit(s) are you using? What shank do they have?
There should be no need to pull the chuck back while inserting a bit. simply apply consistent pressure to bit while slowly turning it in the chuck. if the unit has been maintained, the bit will eventually line up with the chuck and slide in an additional 1/2" or so - locking into place. the chuck only needs to be pulled back to release bits.
Posted on Aug 08, 2009
  • gwoodworker Aug 08, 2009
    btw: this drill uses the "SDS Plus" drill bit interface. If you are using the wrong style of bit, you can damage the chuck...
    SDS Plus bits are manufactures by several different companies. My experience tells me Dewalt manufactures a weak bit, prone to premature failure - Bosh bits are very reliable - but the Hilti bits last the longest.
    Sergeant:
    Champion:
  • 226 Answers
Try pulling the chuck back at the same time turning the bit while installing it should drop into place release the chuck,then make sure the lever just in front of the trigger is switched over to the rite side to use the hammer action.hope this helps
Posted on Jul 29, 2009
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Trunk is not original. It came from the junkyard and we have no key. How do we open the trunk on a 95 Jag convertible?
If there is no remote opener, or lever to pull, you're going to have to drill out the lock, and change it t one that has a key. Or, if you know where the trunk came from, you could maybe get a key from the junkyard.
The only other option is get the serial number off the donor car, and have a key made.
If you drill the lock out , use about a half inch bit, and drill till it kinda falls apart. You should see a little flat rod in there. If you are able to turn the rod with a pair of pliers, good. If the rod falls out, put a screwdriver in the slot where the rod was, and turn the lock.
Aug 23, 2011 | 1995 Jaguar XJ6
Trying to get the drill bit out and I don't know how???? What do I do to get it out? I want to use a different bit.
put your hand around the nose of the drill and turn counter clock wise until the bit falls out. then put another one in and turn clock wise to tighten it.
Jun 11, 2011 | Dewalt & 14.4V Xrp Hammer Drill
Broke bit inside chuck and piece is lodged in there now. Pulling out on chuck release does not allow broken part of bit to come out. Do I need to take drill apart or remove chuck to get broken bit out of...
TAKE THE OUTER CHUCK PEICES OFF THE IMPACT!! THERE WILL BE A C-CLIP, WASHER, SPRING AND ONE OR TWO BALL BEARINGS AND THE OUTER HOUSING, IN THAT ORDER! WITH ALL OF THAT OFF, MOUNT THE ANVIL IN A BENCH VISE WITH BRASS JAWS OR BETWEEN TWO PEICES OF WOOD, UPSIDE DOWN!!!!!!!!!!!!!!! THE TRICK IS TO HAVE THE BIT FALL OUT OF THE CHUCK ONCE IT IS LOOSE!!!! NOW WITH IT MOUNTED IN THE VICE AND PRETTY TIGHT, TURN THE TOOL ON UNTILL IT FALLS OUT, IT WORKS GREAT IF HAVE DONE IT ABOUT 75 TIMES!! MOST PEOPLE THINK I'M A WIZARD!! BUT IT'S REALLY EASY. WITH IT MOUNTED SOLID IN THE VISE THE ANVIL HITS SO FAST AND HARD IT VIBRATES THE ANVIL, IF YOU DO NOT REMOVE THE BALL BEARINGS HOLDING THE BIT, YOU WILL BE DOING THIS ALL DAY. SOMETIMES, IN THE CHEAPER BITS IT WILL ROTATE AND GALL UP SO BAD THAT IT WILL NEVER COME OUT, IN THAT CASE YOUR BUYING A NEW ANVIL ASSY. JIMS TOOL SERVICE
Jan 11, 2011 | Makita LXT202 BHP451 18 Volt Hammer Drill...
I loosend the drill bit on my Makita cordless drill to much and now it's stuck. I can't loosen it to tighten
That can be cured with WD-40, and 2 pairs of channel lock pliers. Spray the chuck inside with WD-40, then grab the lock collar closest to the drill body itself with the pliers, being careful not to squeeze too hard and damage the plastic, then do the same for the spinner in front of it and rotate it clockwise while holding the lock collar in place.
Mar 24, 2010 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
THE BIT DOESNT STAY IN PLACE
Could be 2 problems, first are you using the right type of bit to lock in this tool and second the ball that locks into the detent of the bit might be stuck or the ring holding it in has moved. Give me a brand and model number and I will find a breakdown for this and see if I can give you more help
Jul 27, 2009 | Black & Decker Pivot Plus Cordless...
Drill bits do not lock in chuck or will not go in at all.
If the picture that I am seeing is of the same that you have then I can tell you that those are special bits that are fluted on the shanks so they can hammer. Also those drills do not chuck up like a regular drill. You have to pull the collar down insert the bit and rotate it until it falls in and then release the collar. Remember these bits are specific to the drill and can be hard to find, a rental store is a good place to find them for sale. Hope this helps. 2rns4u <*{{{>(
Apr 04, 2009 | Makita HR3000C Electric Rotary Hammer
Bosch 11236VS Rotary Hammer Logo
793 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
