Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV won't turn on, no status lights, nothing.
So i was watching tv tonight, and next thing i know, the tv just up and shuts off. i turned it back on after about 10-15 seconds, and it came back on, and then within 30 sec. the red status light came on and the tv shut off again. it is a mitsu. wd-52525. the light was replaced less than a year ago. i have noticed that after i turn it off, a couple hours later, it still sounds like a fan or something is running inside the tv. i didnt pay too much attention to it, but now there are no sounds or anything working on the tv. i hit the reset button, and tried the device/menu combo and nothing. i took off the back, and couldnt find any fuses. i am not much for electric repair, but i was hoping you guys might be able to give me some ideas as to what might be causing the problem. i hope i gave sufficent information.
thanks in advance,
  • broketvman Dec 18, 2007
    tv cuts off after 30 sec red status light comes on reset tv same thing but fan makes noises then ramps up and cuts off
  • 3 Answers
Urn on you tv after it goes off
go to front press menu and device at same time
it will recycle and the green will start flashing
count the cycles a three flash pause and than a 7 flash
will mean a bad fan
there is fan in the back that cools a heat sink
it is easy to get to
sometimes the connection goes bad
you can check your fan
dont order one from mit
this is a standard 3 wire 50mm x50mm computer heat sink fan
take yours out and find one to match
cost about 6-8 dollars unless you have laying form old computers
you have to take off the plastic cover in the back no big deal
with cover off yu will see a metal cover looks like a tunnel at the bottom
three screws removes it wires are under
after removal you will see the fan and heat sink
put you filter on the side back on with the two screws
so that the tv will start plug it back in turn power and see if the fan spins
if not check connects no run after that
than replace this fan
mine worked fine with new fan
if need more help you email me at
Posted on Nov 05, 2007
My TV won't turn on. It was fine this afternoon and when I tried to put in on tonight, nothing.
The key here is does the red power light come on? If not follow power cord inside to the fuse that is directly in line with the cord.
If other let me know.
Apr 23, 2012 | Hitachi 51F510 51" Rear Projection...
RCA 32V434T Flashing Red Light
Flashing protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
13 inch diamond vision t.v. shut off and will not turn back on
Bad HOT transitor next to flyback transformer.If the set is 19" or smaller it will cost more to fix then it is worth.
Apr 17, 2008 | Televison & Video
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Mar 18, 2008 | Televison & Video
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
