Question about Refrigerators
Broken ice maker
I have a Kenmore refrigerator that works very well, except for the ice maker. Water comes out of it, but it won't make ice. What can I do before I have to call someone to come repair it?
  • littlekatzs Jun 29, 2009
    Vic,
    Thank you for your help. When I raise and lower the arm it does advance. The model number of my refrigerator is 106.9535510. I hope this helps.
    Jacqueline
    President:
  • 1,136 Answers
Hi, Does the water go into the icemaker and freeze but will not release into the ice bin? If you raise and lower the arm a few times, will the ice maker advance?
Please get me a model# so I can look this up and assist you further.
Thanks
Vic
Posted on Jun 20, 2009
  • Victor
    Victor Jun 29, 2009
    The ice maker part# 4317943 is a complete kit. One test you can do is, remove the white cover to the head of the ice maker. It will just pop off. Use an inulated piece if wire abiut 5" long and strip each end about 1". Insert on end of the wire ibto the hloe marked M and the other end of the wire into the hole marked N.
    The icemaker should start turning. If it turns, the ice maker will need replaced. If it does not turn or try to tiurn, there could be a power issue t the ice maker. The ice maker is usually the problem. I hope this helps you.
    Vic
    $119.00
Ice maker is not working. doesn't appear that it's
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Have a good day : )
Sep 03, 2011 | Kenmore Side by Side Refrigerator
Ice maker in side by side Kenmore refrigerator model number 106.55529400 has stopped working.The ejector fingers are not stopping in correct position,from what I have read online this means ice maker...
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
.2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope i can help you with your problem.
Have a nice day : )
Aug 22, 2011 | Kenmore Refrigerators
My Kenmore refrigerator icemaker quit making ice. It still cycles through like it's attempting to make ice, we've checked the water line for kinks and blockage to no avail. Don't know quite...
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
Hope this would help.
Good day! : )
Jul 06, 2011 | Kenmore Refrigerators
Wont make ice
2 .Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
Have a good day : )
Jun 09, 2011 | Kenmore Refrigerators
Not cooling
The question is too short so i guess that your refrigerator maybe won't make ice & reason for not cooling so i gave this tip.
Have a good day. : )
Apr 17, 2011 | Kenmore Refrigerators
Refrigerator icemaker stopped making ice. Can you tell me what's going on. The motor was just replaced in it about three mos.
Have a nice day : )
Mar 09, 2011 | Kenmore Refrigerator Replacement Water...
Ice maker won't make ice
Hope i could answer your problem.
Thanks have a good day : )
Feb 19, 2011 | Kenmore Refrigerators
Kenmore elite ice maker stopped making ice,
Hope thiswould help you
Have a good day : )
Jan 01, 2011 | Kenmore Refrigerators
Kenmore side by side ice maker not working, water does work, checked the back not a frozen line. The problem occurred when the compressor/start device was replaced in the summer. The repairman said that...
Hope it help you.
Have a nice day.
Dec 06, 2010 | Kenmore Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
