Trying to connect audio and video cables from a
Trying to connect audio and video cables from a Curtis DVD 1055 player to a ST432F TV
  • 17,130 Answers
Please connect the audio out/videoout from your DVD tot he audio in/video in of the TV. If you have a stereo player connect the right and left channels accordingly.
Posted on Jun 28, 2010
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
I cannot connect the cm25101s to the dvd/vcr playet (philips dvp3345v/17), how will i do it and what channel it should be on and should the tv be on cable r air?
A vcr/dvd player should be connected to the rear audio/video connections on the rear of the set from the same type of connections on the rear of the combo player.
Select the input connected to on the tv and go.
Mar 23, 2012 | Curtis CM25101S 25" TV
I just bought a Curtis 1041 dvd player I set the player up I am receiving sound from the DVD but no picture. What is wrong
hi,
connect the dvd player to the tv insert a disk then press the progressive scan (proscan) button on the remote control. If the progressive scan is on then there is a possibility of video missing in some tv's. If then also there is no video then you have to check the video cable. Try with some othere video cable.
If the problem previes after replasing the video cable then the video processor in the dvd player is fauly. You will not get this video processor in the oppen market. Only way is replasing the board.
ok
Sep 24, 2011 | Curtis DVD1071 DVD Player
I am trying to install a Curtis DVD5088 with its sound system not only for use with the DVD Player, but, the TV as well. I have a TV cable service which I would like to connect as well. How can I install...
Use RCA cable Red and white for audio in ans yellow for video input to the television set . and use the remote control for change over input options.
Feb 06, 2018 | Televison & Video
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Connection to my old TV
your tv do not have an audio/video input...what you need is a device called RF modulator, it converts the audio/video signal from your dvd player into RF signal similar to the signal from the cable operator.it has an audio/video input and a coaxial cable output..
Jul 18, 2009 | Curtis DVD1047 DVD Player
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Trying to connect dvd player
You will have to connect your DVD player to the plasma TV, not the cable box. The cable box (or most cable boxes) have video outputs only. The same is true for the DVD player: it outputs the video to the tv.
Look in your DVD manual for scenarios for connecting your player to the tv.
Mike
Dec 06, 2007 | Panasonic DVD-S27 DVD Player
Can't find my user manual and need help hooking it up
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
Jul 30, 2007 | Curtis CMD5000 DVD Player
70 people viewed this question
 Grubhead
Grubhead
