Question about GPS
I deleted all files from my navman f10 by mistake,how do iget them back
    President:
  • 1,111 Answers
Someone here will be able to help you..its not a quik fix if you deleted everything.
http://www.gpspassion.com/forumsen/default.asp
Posted on Jun 21, 2009
Hi there, i need the original files of the navman
Check online type in name and serial number
Sep 22, 2013 | Navman F15
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
Screen is frozen, can be turned on and off but wont go passed initial stage
May 17, 2010 | CaseCrown Navman S50 Portable GPS...
Operating manual for navman f10,GPS
You can download the same from :-
http://safemanuals.com/user-guide-instructions-owner-manual/NAVMAN/F10-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 28, 2009 | Navman GPS
Reset navman F10 sat nav
Press and hold the on/off button for ten seconds will re-set the system on the satnav. If the screen freezes after loading the maps then connect the Satnav to a pc via a usb lead and download the latest Service update fom Navman.com. With the Satnav connected to the computer and the download compleated double-click the F10 set-up.Exe and it will update the system on the Satnav. Once complete disconnect the cable and restart the F10. That was the way I sorted mine out after recieving 'little' help from Tech Support from Navman.com. My problem seems to be in the Multi-drop ability of the F10 [program one location and try and add another to plan a route] but I have never got anyhelp from the tech's other than "Buy a Connectivity kit from us and you may be able to use that to fix the problem....". If you get a "Not enough memory to complete update... " message after double clicking the F10 set-up, you will need to go into your F10 Satnav memory and look up some of the saved files from previous routes you have stored in there. I deleated some of these to free memory and it didn't seem to affect the Satnav's programming and allowed the update to complete. My F10 started fine after that. If you need any more help, Navman.com tech support may be able to suggest something....., just don't hold your breath....
Sep 23, 2008 | GPS
Navman F10 Software Update
Hi, I had the same issue. Found the Navman F10 software via the navman New Zealand website.
link: http://www.navmansupport.co.nz/Software/F%20Series/F10/NDD001___347.htm
once downloaded the F10 PC software, redownload your language voice to the F10 from the navdesk software you just installed on your pc.
Note: if the voice is already on the f10 and it's not working, try removing it then redownloading the voice again.
Once downloaded to the F10 select the required voice from the settings menu.
cheers.
c.ellis.
Jun 06, 2008 | Audio Players & Recorders
Unable to register newly acquired GPS Navman S80 on your address at www.navman.com.au/register
Also unable to regster my s90i which is giving me wrong directions. Wirimu
Apr 11, 2008 | GPS
Navman f10
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
Jan 12, 2008 | Navman F20 GPS Receiver
GPS Logo
329 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
