Question about HTC Verizon XV6700 Cellular Phone
My pdd no detect sd card
Say: no instaled
  • 450 Answers
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Posted on May 12, 2010
Unable to share file pc to mobile through sd card reader.
This happened to me too. I solved this by buying a sd card reader that reads new sd card thst are sdhc or sdxc.
Also check device manager on pc if its conflicting with some other hardware
Mar 15, 2016 | Cell Phones
Not able to access play store, sd card and, some settings on kyocera rise after factory reset
you must do a system update to latest software version in order to access play store
Nov 20, 2013 | Cell Phones
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
My cliq says no sd card detected wen there is a sd card. Why can't the phone detect it?
there may be some files corrupted in your sd card...you should formate your card and then try.. i hope this will solve your problem..
Apr 22, 2010 | Motorola Mobility CLIQ Cell Phone
SD card can't be detected by the computer
Did you install your memory card reader drivers?
If you didnt, install it and it will read your SD card.
The drivers should come with the CD that came with your laptop.
You can also purchase a usb SD card adapter, it is not costly.
Dec 30, 2009 | Averatec 3200 Notebook
My micro sd not detect plz hlp
you must install driver package for you windows.
you might get on internet
Apr 15, 2009 | SanDisk 2GB microSD Memory Card
Cannot detect SD flash memory
check in "my computer" and see if it registers as a removable drive there. If not, then check in the device manager while the card is inserted and look for any yellow icons. There is a chance that the card reader need a driver installed or updated.
Hope this helps.
Mar 30, 2008 | Acer Aspire™ T180 PC Desktop
Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Oct 07, 2007 | HP iPAQ HX4700 Pocket PC
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
HTC Verizon XV6700 Cellular Phone Logo
60 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
