Question about Frigidaire ATF6000ES Front Load Washer
Stop making ice and stop working periodically, so melting
When this happens, there is some frost in freezer
    Sergeant:
  • 212 Answers
Unit not going through defrost cycle
Posted on Jun 20, 2009
How to defrost
If this is an automatic defrost or "no-frost" freezer and it has developed a lot of frost and ice, call a repairman. That should never happen.
But if it's a manual defrost model, follow this procedure.
1. Turn off the freezer. Then remove all the food and toss it into a picnic cooler to keep it frozen. (Some blue ice packs will help.)
2. Open the drain on the bottom of the freezer, and put the end of the hose from the drain (which most have) into a roasting pan to catch the water from the melted frost.
3. Leave the door open. If you have a small electric space heater, blow warm air into the freezer to speed up the melting process.
4. Don't scrape the ice -- you could puncture a cooling coil in some units, making the freezer useless.
5. In about 30 or 40 minutes (15 with the space heater) the ice will be melted.
6. Dry the interior with a towel, toss the food back in, turn the freezer on again, and you're done.
Jun 02, 2015 | Frost Freezers
How does Auto defrost work and how long does it take
Hello there
A Look at the Defrosting System:
Modern refrigeration systems, whether industrial or household, feature a defrost system. A refrigeration system works by developing temperature below the water's freezing point. Long hours of continuous operation may lead to development of a layer of frost or ice around the freezer or the evaporator coil. This hinders the cooling capacity of the evaporator, making it difficult for the cooling effect to pass into the freezer. Without refrigerator defrosting, the layer of frost or ice leads to loss of cooling and lessening of performance coefficient of the refrigerator and higher electricity costs. There are various defrosting methods that your fridge can employ. Take a look at some of these defrosting methods.
Thermostat Defrosting:
Thermostat is a basic component in all modern refrigerators. The device allows you to set the freezer temperature that you want, depending on your requirement. Most often, a refrigerator with thermostat comes with a small plastic tray which can be found below the freezer compartment. This tray is where the excess water from your freezer goes to. The thermostat works by stopping the supply of power that is received by your compressor whenever the temperature that you have set has been reached.
The refrigeration unit stops producing the cooling effect whenever the thermostat stops, which happen several times a day. And during this stage, the frost or ice collected on the freezer starts to melt, with the resulting water collected in the tray. A small tube connects the tray to a small outlet usually located at the bottom back side of your refrigerator. A pan is installed there where the tube brings the water resulting from melted ice after defrosting.
Mar 01, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Jul 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
My freezer leaks when not freezing
Drain tube
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Mar 02, 2010 | Refrigerators
Leaking from underneath the front periodically. If there is a tray, I cannot find one. Water runs from the bottom every three or four days.
Sep 16, 2009 | Refrigerators
Water is running from the back of the freezer compartment and periodically seems to defrost and run out of the door and flood the floor Can you hepl
Sep 15, 2009 | Fisher and Paykel Active Smart® E522BR...
Ice maker quit working
Sep 07, 2009 | Refrigerators
Kenmore Model: JSI-23, two door (water/ice)
Aug 22, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Icemaker making too much ice & Freezer frosting up.
Hi gpss,
It sounds like you are getting large amounts of warm moist air into the freezer. This can be caused by the door being left cracked open or the door seal not sealing properly. Check your door gaskets on both sides of the refrigerator. One other possible is the ice chute. If it is not closing all the way it will cause the same problem. You will get alot of frost forming in the freezer then it will melt when the refrigerator defrosts. Let me know if this helps, and if you have anymore questions.
Mike
Sep 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire ATF6000ES Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
