Question about Amana NDE2335AY Electric Dryer
No power to control panel
There is no light on the control panel and the dryer will not start. I know that the problem is not the electrical outlet because the light turns on when I opent he dryer door. Is the problem a faulty electrical control board is there another possiblity?
    Sergeant:
  • 212 Answers
Thermal fuse bad
Posted on Jun 20, 2009
Dryer has no power to control panel, inside light etc How do I restore.
is it gas or electric?did you make sure there's power at the outlet?if it's electric,look at the back of dryer where the cord connects,remove the cover and with a meter make sure you have 240 volts there.you need to send the full model number off of dryer,this could have a computer board in it but if the inside light is out it sounds like no power going to it.
Oct 07, 2017 | Power Computers & Internet
Dryer shuts off after one minute
  1. Lid Switch Doesn't Latch
    • A Whirlpool Duet dryer has a latch on the interior frame of the door. It essentially locks the door closed when the dryer is operating to keep you from opening the door and becoming injured by the tumbling drum. The dryer can only run when the latch is secured. If the latch breaks, a dryer might start but shut off prematurely. Open the door and press the latch down with your finger. It should make a ticking sound when you release it. Replace it if it doesn't.
    Unsteady or Damaged Power Cord
    • A dryer's power cord delivers electricity from the electrical outlet to the machine. If the power cord isn't firmly plugged into the outlet, it can interfere with the electricity transfer. While your Whirlpool Duet dryer might start, it probably will shut off soon afterward if the cord is wobbly. Also, if cords wires are visible through the rubber encasing, the cord might be defective. Though the dryer turns on, a faulty power cord might not be able to sustain the dryer's long-term operation.
    Triggered Thermal Fuse Faulty Control Panel
    • The Whirlpool Duet dryer's control panel operates with the support of multiple wires that link to various dryer components. After you choose a drying setting and turn on your dryer, the control panel begins running elements of the dryer. If one of the wires fails, it can disrupt the performance of your dryer. Contact a dryer repair specialist if you suspect that the control panel might have short circuited. If your dryer is still under warranty, rather than replace the corrupt wire, he might recommend replacing the entire panel.
Dec 11, 2013 | Dryers
My KEHS01PMT Kitchen Aid Electric Dryer does not work at all after the 240V supply dropped to 120V ... due to a supply problem. We fixed the electric supply and verified we have 240V at outlet and at the...
You may have a faulty ground but that should have been caught by a good volt meter.
Depending on your supply issues, the board could have been damaged and replaced.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link may help you out, if not ,contact your power co. or supplier.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 23, 2017 | KitchenAid KEHS01PMT Electric Dryer
Dryer will not turn on - checked power at outlet - it is ok - light does not turn on inside either. There is a light vibration if you plug it in ( if your hand is by the control knob - will a slight...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 21, 2010 | Maytag PYE2300AY Electric Dryer
I have no power dryer interior light works but nothing on panel?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Jan 02, 2010 | Maytag PYE2300AY Electric Dryer
No power to selector panel
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
Frigidaire LEQ1442ES won't start
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
Also check the electrical output from your house;
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Hope this initial info helps
Jun 13, 2009 | Frigidaire Electric Dryer
Dryer will not start
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Amana NDE2335AY Electric Dryer Logo
116 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
