Question about Microsoft Wireless Notebook Optical Mouse VSBX300008
No red light on mouse. Green light on for part connected to compu
I have not used this mouse in a long time
    Problem Solver:
  • 8 Answers
Go make sure your battery works or...(this happened to my friend i laughed at him):maybe u putted the battery upside down lol
Posted on Jul 04, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Logitech wireless mouse not working
Go to logitech's website and navigate to support/drivers/downloads and look for the exact model of your mouse. You may have to temporarily use a P/S-2 mouse which would have a green connector on it in any case, it would plug into the tower or laptop at the green connection port. The purple one would be for keyboard. If can't do, then borrow someone else's pc and download the driver to a CD or flashdrive then use it to install driver.
Install the driver using the old mouse for now, then just after you give the command to reboot, pull old mouse or the P/S-2 mouse out and plug in the USB wireless device for your wireless mouse at this time. Reboot and should fix.
Your issue is either driver related or defective mouse IR no good (infrared)
I'll point you in the right direction but can't help any further without the exact model# of your w-mouse.
http://www.logitech.com/index.cfm/support_downloads/downloads/mice/&cl=us,en
Jan 02, 2010 | Logitech Cordless Mouse
Hi, I have the wireless mouse 3000 and I just changed my batteries but on the receiver I can't get the green light to work. I tried pushing the button on the receiver but nothing. Any idea? The mouse has...
Try putting the receiver in another USB port on your computer. If it still doesn't light, push the button on the receiver and the reset button underneath the wireless mouse (you might need a pen/pin to do this) for approximately 10 seconds at the same time. The receiver and the mouse should now be synchronized.You should be able to use your mouse and and receiver should be giving a steady green light. If not, you will have to consider that the wireless mouse receiver is busted.
Nov 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Red light doesn't come on ~ Microsoft optical notebook mouse 3000
Look for a small button that protrudes where the receiver is placed at the bottom of mouse. There are two possibilities for turning on the red light, one is that said button is stuck,if that is the case push it down a couple of times and see if the red light goes on, the other is that the button is broken at it's base. Also check that battery contacts are clean and hold it firmly. Good luck!!! Chawah.
Mar 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
MOUSE LIGHT FLASHES red and green; does not function
The flashing red and green lights means that now it's in discoverable mode and it's time to add it as a bluetooth device.
Mar 14, 2009 | Microsoft Wireless Laser Mouse 5000
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Mouse Wireless Model 1023/1024 won't work
try using an eraser on the contacts if you can reach them. Sounds like dirt/corrosion build-up.
Jun 15, 2008 | Microsoft Wireless Notebook Optical Mouse...
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Microsoft Wireless Notebook Optical Mouse VSBX300008 Logo
222 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
