Question about Logitech Marble Mouse Trackball
SetPoint messed up my Synaptics touchpad.
I installed SetPoint for my Logitech mouse and now my touch pad speed is low and I can't use the scroll on my touch pad. I have to reset this after every re-boot how do I fix this problem or go back to the point before I installed Setpoint.?
    President:
  • 2,712 Answers
Go to Start > Run > type "msconfig" (without quotes) > OK > tab Startup, find entry C:\WINDOWS\KHALMNPR.EXE and untick it. Click OK and reset your computer. After logging on, open Control Panel and restore your mouse settings like you had it before installing SetPoint.
You can also try this:
In SetPoint you can go to the Mouse Game Settings (the chess piece), from there, click "Enabled" for Game detection, then click "OS Implementation" under Speed and Acceleration.
Hope that helps. Kindly rate the solution if it helped.
Cheers!
IrishDruid
Posted on Jun 23, 2009
Lock access to the registry entries under [HKEY_CURRENT_USER\Control Panel\Mouse] for yourself using administrator privileges (after setting up your settings) and SetPoint can't change them anymore! :-)
Posted on Jul 01, 2010
Mouse pad won't work
Reinstall the driver for the touch pad. If tha still doesn't work, I would suspect the touch pad itself and buy a new touch pad for your laptop, or an external usb/wireless mouse.
Dec 22, 2013 | Sylvania G-Netbook
Scroll bar in my touch pad is not working
Go to control panel then mouse properties and see if it needs to be reconfigured. Sometimes they just change on their own if you are using a mouse as well as the touch pad, remove the mouse (device), then reinstall the Synaptics touch pad software and try setting it up. You may have to turn on that function in touchpad control settings.You can reinstall the touchpad driver, be sure though that it's for your laptop's model.
Dec 10, 2010 | Dell Vostro 1015 Laptop
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
I have a problem with my laptop, my scroll thing won't work in the touch pad, i need help?
The touchpad in those units is made by a company called Synaptics. Go to this page and download the drivers for your operating system. http://www.synaptics.com/support/drivers
You will also need to go to Start, Control Panel, Mouse, and set the zones on your touchpad. My guess is after the driver install, you will find the scroll zone is set too small and need sto be adjusted.
Jun 04, 2010 | Compaq Presario CQ60-212US Notebook
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
Touch pad
First check if your Synaptics Touchpad is well configured in System Panel ---> Hardware, under "another pointing devices".
If so, then go to Control Panel ---> Mouse ---> Synaptics Touchpad. There you can enable/disable properties.
To get the pad properly setup, you should try to download and install te SP21661 pack from HP/Compaq, that pack comes with all the features you can use, very useful for W2K & WinXP.
Link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-28135-1&prodTypeId=321957&prodSeriesId=96221
Lucas from Argentina
Dec 26, 2008 | Compaq Armada 1700 Notebook
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Nov 04, 2008 | Logitech V220 Mouse
Logitech Marble Mouse driver/setpoint messed up my synaptics touchpad on my laptop...can't fix this!
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Oct 24, 2008 | Logitech Marble Mouse Trackball
Scroll touchpad broken at my gateway T 6321
I guess that some settings with touch pad might have changed.
try accessing the touch pad controls in the control panel.
may be its called synaptics ....
lemme know if it works :)
Aug 06, 2008 | Computers & Internet
Logitech Marble Mouse Trackball Logo
908 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
