Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
The dishwasher will turn on but it wont pump the water into it.
It turns on but it doesn't wash
    Problem Solver:
  • 3 Answers
I have a F&P Soft Touch Which was'nt going .A serviceman came and pushed down on the top and it went and has ever since.The top can become slightly bowed so so the door switch doesn't make proper contact.
Posted on Jun 26, 2009
    Sergeant:
  • 212 Answers
Replace float switch
Posted on Jun 20, 2009
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
How do I find the pump on model #she44c06uc/48? Dishwasher wont pump water out?
Hello
When you say pump out water, do you mean the drain pump used to empty the hopper? Usually dishwashers have two pumps, one to empty it and one to supply water to the wash arms. If it drains but doesn't spray it sounds like spray supply pump is gone. Could be just a loose connection or it a dodgy contactor or relay, or the pump itself. Someone with a very basic knowledge of electricity and a multi meter could very easily diagnose this and you may be able to order the part.
Sep 07, 2011 | Dishwashers
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
My d/w wont drain the water
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 18, 2011 | Dishwashers
My dishwasher wont drain.. water stays in the tank..
When you run a dishwasher, there is usually food particles left over from a cycle. First thing is to check the lent screen. The lent screen is located on the bottom usually in the back of the dishwasher. If you want to put some gloves on and remove it and turn on the drain cycle on your dishwasher. If that doesn't do it turn off the power to the dishwasher by the breaker box, and check your hoses inside the dishwasher.
May 11, 2011 | Maytag 24 in. Built-In Dishwasher w/...
After dish washing water does not drain.
Hi
Daniel
Apr 21, 2011 | Dishwashers
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
272 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
