Question about Star Logic 17" LCD Monitor
Exact same as above
TUrns on works for ~ 40 seconds the black can turn off then back on., works for ~ 1 second. That fix seems both technically challenging for me, as well as expensive. Is there another solution? Or is it actually cheap to fix?
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 20, 2009
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
TV model 40RV753. Brand new. Setting up problem. Red/green light goes green for a very short time, during which 2 short 1 second bursts of an image with sound. light then turns to a flashing orange...
Hi Gordon,
Did you fix this problem? I have exactly the same model with exactly the same problem. I've checked the capacitors on the PSU board (as suggested in one of the responses above) and they all seem OK. If you fixed the problem, I'ld really like to know the solution. Many thanks.
Regards,
Harry.
Jan 29, 2011 | Toshiba 40RV525R 40 in. HDTV
LG monitor turns on for a split second and then goes black
Sorry to be the bearer of bad news but you called it, the monitor needs to be replaced.Now all we have to do is set the actual time of death...only kidding. Take care, Dana
Sep 13, 2009 | LG Flatron L1750S 17" LCD Monitor
Turns on the shuts off
I had the same exact problem!!!! If you unplug it, then plug it back in after a couple of days. You will hear a frying sound then a loud clap!!!! Solution: Replace it with a LCD.... Not worth getting fixed!!!
May 26, 2009 | Emerson DTE315 TV
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
75 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
jd83854
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
