Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Poulan trimmer , will not stay running ?
The trimmer will run on chock but die's when i give it gas ????
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Carburetor may be set to run too lean. This is a common problem for out-of-the box poulans. You will need a special tool to adjust the the screws:carb adj. tool . Try ebay or amazon.
Posted on Jul 16, 2009
I have a poulan pro link 33cc sting trimmer it runs for a while then it dies or I give it it wants to die out an bog down anyone know what to do
Fuel filter!
They are located in the gas tank.
Use a hook to grab the fuel line/tubing, there will be enough tubing to pull the filter out of the tank. Filter will be on end of tubing.
Replace it. Hope that helps you out.
Good luck.
look here...
May 19, 2015 | Poulan Garden
Poulan te450 xl
Probably the metering diaphragm, or the low side of the carb needs adjusted counter clockwise in 1/4 turn increments.
Jul 10, 2014 | Poulan 17" T&E Gas Trimmer
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Feather lite trimmer only runs on half throttle and idle dies on full throttle. unit is new
When I bought a new poulan gas trimmer, I had the same problem. Solution was to return it and get another one. They come with problems, even new. Just keep returning them until you get one that works correctly. Mine works great, but like I said, had to return it and get one that was right.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a poulan 25cc trimmer (P1500). It's about a year old. Recently, after trimming for 15 or 20 minutes, it tries to stall out... eventually it dies and will restart and run briefly then dies again. Any...
You can check a few things. Either the air filter is plugged up and the carb isn't getting enough air. Or you got a small piece of debris in the carb. Sometimes if it is debris stuck in the carb then you can just keep starting it over and over again and the debris will dislodge itself.
Sep 15, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Poulan Woodshark Model 1850. It starts, runs for a few seconds and dies. Help!
Try fresh gas with correct oil mixture. Carb might need cleaning and adjustment. Also try leaving chock closed and see if it runs longer before dieing...if it does, it indicates that it's not getting enough gas which could be solved with the carb cleaning and adjustment.
Jul 29, 2009 | Poulan Garden
Polan pro pp133
Are you saying that this is a brand new trimmer or is it new to you, used trimmer? You are describing a problem that is typical of a used trimmer.
This is a sign of a clogged gas cap. When the gas cap can't breathe, it chokes out the carburetor.
Try this: The next time you run the trimmer, and it starts to die, loosen the gas cap, it should start running again.
Jim
Jun 22, 2009 | Poulan Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
975 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
