Question about Arcsoft TotalMedia Extreme - Windows for PC
Cannot uninstall arcsoft total media
Using regular '' add and remove programs'' doesn't uninstall the program.
It opens a window in arcsoft offering the unistall but then quits the unistallation program without doing anything
    Sergeant:
  • 220 Answers
I would advise for you to use a program like revo uninstaller that does it all for you.
Its freeware at http://www.revouninstaller.com/revo_uninstaller_free_download.html
Hope it helps
Posted on Jun 20, 2009
A window keeps popping up saying arcsoft connect daemon has stopped working. how do i correct fhis problem. i am not an expert so please go easy
Hello, Arcsoft is a suite of media handling programs. Arcsoft Connect is used for online connection (updates, new goodies etc). It would be odd if you have 'Connect' without any other of their products, so you might want to uninstall those first if they exist In order to remove that from your computer lets try these methods. Method 1: If it is installed into C:\Program Files, you may be able to uninstall it via programs and features.
To do that follow the link provided below. Uninstall or change a program
http://windows.microsoft.com/en-US/windows7/Uninstall-or-change-a-program
Method 2: Try disabling the "ArcSoft Connect Daemon" service from Services before you start. To do that you need to follow these steps: 1. Click on start button.
2. Type in services.msc in the search field.
3. Now locate the "ArcSoft Connect Daemon" service and right click on it and select disable. Now reboot the computer and check if the issue gets resolved. Method 3: If the above method doesn't resolve the issue, you may try downloading the windows installer cleanup utility and install it on your computer and try removing the arcsoft program and check for the issue. To do that you need to follow the links provided below. Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/kb/290301
For clean up and installation you can refer to the below mentioned link:
http://support.microsoft.com/kb/923100
Add this link to download windows installer cleanup utility:
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Sep 16, 2011 | Arcsoft Computers & Internet
Every time i start up my laptop w/OS windows vista i get a window which says arcsoft connect daemon, not working or something like that. if i try to update it says its the updated version. is this a trial...
Have you tried going to Control Panel>Programs and Features and uninstalling the arcsoft program? If that doesn't work, do the following:
  1. Open the Start menu and go to Run... Or, if Run... is not available, skip it and go to the little bar you can type in at the bottom of the start menu
  2. Type "msconfig" (without the quotes)
  3. When the window pops up, go to the Startup tab
  4. Find the arcsoft entry and disable it.
  5. Reboot your computer. The msconfig window will open up again to be sure that your settings are the way you want them, you can just close it.
Jul 27, 2011 | Arcsoft Computers & Internet
Im wanting to remove some of my arcsoft programs that i do not use which ones can i remove without affecting the basic program?
First, make sure you have the Arcsoft disk in case you change your mind. I remember seeing the Arcsoft programs several years ago, they came with some printer I bought. If you have your Arcsoft disk, then you are free to experiment with options.
Look under Add/Remove Programs, and see how many entries you see for Arcsoft. There may just be one, I don't really know. But if there are several, then try to make intelligent choices about what you remove and what you keep. I'm not sure what you're using this for - - - anyhow, it says "Cards and Calendars", so those are the 2 main functions. Maybe if you're not using Calendars, you could remove that.
But I have a hunch it's probably just a single suite with these 2 functions built in. Let me know if this helps.
BTW, if you don't have your Arcsoft disk, I would not recommend uninstalling ANY part of the suite. For example, if it came pre-loaded on your computer, the only way to get it back may be to do a total, "factory reinstall" where you format the hard drive and put everything back the way it was when you bought it.
Thanks ~Jim :-)
Jul 22, 2011 | Arcsoft Print Creations - Cards &...
I want delete ArcSoft MediaImpression2 from Add or Remove Program but cannot. When I click Remove button, nothing happen but the file is still there. I need your help/ Thanks in advance
Click here to download and install ccleaner.exe
This program is free for you
once started, access the add/remove programs tab on the left hand side and select the program you want to remove and click uninstall. If you cant uninstall still, you can remove it from the systems program log, as it may be corrupted or may have uninstalled correctly, but left the file that windows reads in order to say it is installed.
GOOD LUCK AND RATE HIS POST AS FIXYA!!!!
May 13, 2011 | Arcsoft MediaImpression 2
Arcsoft connect has stopped working
Hi, Arcsoft is a suite of media handling programs. Arcsoft Connect is used for online connection (updates, new goodies etc). It would be odd if you have 'Connect' without any other of their products, so you might want to uninstall those first if they exist In order to remove that from your computer lets try these methods. Method 1: If it is installed into C:\Program Files, you may be able to uninstall it via programs and features. To do that follow the link provided below. Uninstall or change a program
Feb 13, 2011 | Arcsoft Computers & Internet
I want to uninstall
I'm assuming you mean an ArcSoft application/program. I'm also assuming you mean for a Microsoft Windows operating system. If those assumptions are correct. Then simply go to the Control Panel and select Add/Remove Applications. ArcSoft will be listed. Simply select it and choose to uninstall/remove.
Aug 26, 2010 | Arcsoft Computers & Internet
Trying to uninstall arcsoft webcam companion
if you have window xp:
go to start, control panel, add or remove and then click on the webcam in the list. Now, you will see an option, remove, click on remove and follow the on screen instructions,.
if you have window vista or window 7:
go to start, control panel, program and feature and then click on the webcam in the list. Now, you will see an option, Uninstall, click on Uninstall and follow the on screen instructions,.
if it is not being uninstalled then install the following program and uninstalll your web cam application using it.
Dec 02, 2009 | Arcsoft Computers & Internet
Will not uninstall, tried to unistall on uninstall,but it says will not
this is caused by it corrupting on the registry use xp/vista registry cleaner to solve this and try uninstalling again
Oct 02, 2009 | Arcsoft PhotoImpression® 6 Full Version...
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
Antivirus2008
You can uninstall the software by following this :
Start-control panel-add/remove programs
All the installd programs will be listed.
Just select which you want to remove & click on remove.
Wait it will uninstall the software.
Restart the system.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Microsoft Windows XP Media Center Edition...
Arcsoft TotalMedia Extreme - Windows for PC  Logo
4,292 people viewed this question
Top Arcsoft Computers & Internet Experts
Marvin
Marvin
aravind shet
aravind shet
Pierre Legault
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
