Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Light bulb does cnot work
I replaced the light bulb on the fridge side and when you open the door it does not come on
    Sergeant:
  • 212 Answers
Replace door switch
Posted on Jun 20, 2009
    President:
  • 1,136 Answers
Hi, Sometimes when you put the bulb in, it feels like it is in all the way but just needs another 1/4 turn. If you use a rag and grab the butl with the palm off you hand, try and turn it a little more.
If that doesn't work, loosen the bulb a little and tighten it up again. Also, make sure you are using an appliance bulb instead of a regular household bulb. The appliance bulb will last longer.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
My interior lights in my Viking VCSB423 are out, I tried replacing 2 of the bulbs, it went out after door was open for an extended period of time,(like 10 minutes)
sandra, not being sarcastic but why keep the fridge open for ten minutes? It can cause other problems too. Try not to keep the fridge open for long after bulb change and see if it works. Good luck.
Oct 21, 2014 | Viking VCSB423 Side by Side Refrigerator
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
Inside refrigirator light stopped work. Bulb is ok; works in other lamps.
The likely culprit is the door switch on fridges in general. This because it is basically the only moving part in the circuit. Depending on it's location, it may be subjected to condensation, extremes of temperatures or even spilled liquids that dry and become sticky - resulting in the switch not popping out when the door is opened. Also inspect the light bulb socket itself for dampness or white, flaky dust-like particles. Do NOT attempt to clean the socket while the fridge is plugged in. These last two possibilities should be checked first, as the others are a little more involved.
If the door switch pops out with the door open - it means the internal workings of the switch are probably bad, or may be something else entirely. Locating the problem will require disconnecting the power cord and disassembling parts of the fridge in order to gain access to the switch terminals and related wiring. In the case of dampness or other debris in the light socket, it can be wiped clean now that the fridge is unplugged. Try a new bulb in the socket and plugging the fridge back in before proceeding. A meter and understanding of electrical test equipment along with the fridge's service manual will be needed to continue from here with the fridge unplugged again.
Even without a meter (and the rest of the items listed above) you could simply remove and replace the switch if it is suspect - and hope that it was the cause of the failure. Pay attention to orientation of the switch, any clips, screws or fasteners holding the switch in place. Disconnect wiring only after sketching or photographing the switch and the wires that are connected to each of the terminals. Remove and replace the switch and wiring. Plug back in and test the light.
Good luck - I hope this was helpful!
Dec 23, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Light is off in fridge and the bulb is NOT burned out
first unplug the machine then:
check the lamp scoket for flattened metal bars
if they are not touching the bulb pull them up to contact the side and, bottom of the lamp base replace the bulb and plug the machine in then:if that didn't work; if you can substitute another new identical bulb then: check again next check for a broken door switch
Apr 06, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Refrigerator light doesn't work
then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Feb 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Dec 12, 2007 | Kenmore 53642 / 53644 Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
