Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH-3 washer will not drain. We've reset the breaker, checked the water hoses and still it will not drain and now the door will not lock. Help!
    Sergeant:
  • 212 Answers
Replace washer
Posted on Jun 20, 2009
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
I have a Maytag front load washer. The washer will not drain and the door will not unlock. All of the power sources and hoses have been checked, is there a way to manually unlock it?
If you have a wet dry shop vac you can use it. Connect it to the end of the drain hose and remove the water that way and the door should unlock.
Once the water is gone you will need to check the drain pump and hoses for anykind of obstructions.
Jan 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Washer won't drain maytag neptune washer MAH-3
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water fills and overflows the dispenser department.
if car over heats u might have a head gasket problem or ur thermostat is stuck not letting the fluid circulate
Mar 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
762 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
