Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Our Whirlpool thin twin stopped after filling.
The machine was empty of water after a load but had not done the spin cycle. I started the maching again at the beginning of the cycle and all it did was fill, no agaitation, no spin, no pump out of water. The maching will do everything but spin when the lid is up when it is working normally, so I do not think that the lid switch is the problem. I can hear a faint hum when the ktimer knob is pulled to turn the machine on. Please help. Thank You.
    Sergeant:
  • 212 Answers
Replace lid switch
Posted on Jun 20, 2009
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Thin twin washer basket is VERY off balance and once a cycle runs, there is water filling up under the washer / spin basket.
You should be able to put it in spin and remove the water. if it don't you have a problem somewhere. There should be 3 springs hooked to the bottom of the tub to hold it on center if one breaks or comes loose it will be off balance. If you get water in the tub when not useing it and the water is on from the water line the water valve is leaking.If the water don't shut off when filling the water level switch could be bad.or the tube running to it could be stopped up pull the hose off the water level switch and blow through it if it bubbles in the tub it is ok. If can't blow through it it is stopped up.Hope this helps
Mar 12, 2017 | Whirlpool LTE5243DQ Combination...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
615 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
