Question about Sony Playstation 3 (PS3) Console
Powers on - no output to TV
Greetings, Problem with PS3. Got hit by power surge which apparently fried my cable box, both my HDMI inputs on TV. Replaced cable box and can connect via RCA plugs but not HDMI and get picture fine. Tried both PS3 and HD player neither works thru HDMI but HD player works fine via RCA. PS3 lights come on but nothing else.
Any suggestions appreciated greatly.
Bill
  • jpbill606 Jun 20, 2009
    Thanks you for your advise.
    Bill
  • 6,784 Answers
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Posted on Jun 20, 2009
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
60GB PS3 had been hit by a power surge. HDMI not working.
hook up the ps3 thru the regular yellow composite and HDMI. Go into the settings and change the output to HDMI and then see if you can get video thru the HDMI, if you don't then the mainboard is bad and you would have to send it to Sony unless you can get your hands on another broken sony ps3 with a good main board.
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hdmi connection doesnt work on ps3
By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
May 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
175 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
