Question about Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic DMC-TZ3 Damaged lens rings
Camera was droped in case. But fell on end squashing outer and inner lens rings. On switch on lens will not activate as it is jamed by bent lens rings.Can I replace lings my self or is it best done by expert and what might it cost
I think the colours have gone behind the screen can it be repaired lumix tz7
Posted on Jul 30, 2009
When I turn on my Panasonic DMC-TZ3, It gives me a "Please turn off camera and then on again" message. How do I fix this?
I HAD THE SAME PROMBLEM WITH MY TZ3, I AM KIRAN FROM BANGALORE, MY CAMERA WAS SERVICED BY PANASONIC SERVICE CENTRE-MATA ELECTRONICS ,NO86,1ST FLOOR, SP RD,OPP TO VIVEK COMPLEX ,BANGALORE. AND NOW MY LENS IS DOING PERFECTLY FINE. MR VIJAY IS INCHARGE AND THE CAMERA IS DOING GOOD, CONTACT MR VIJAY 9035871324 08022130711
Nov 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My Panasonic Lumix DMC-TZ3 was soaked in water. It isn't working, will it work when it drys out?
It depends on how wet it was, if the entire thing was submerged, or even a large portion, it probably will not.it may turn on but it is likely that the lens will be damaged permanently. However if it was just wet upon the outside, like it was used out side during a rain fall, and then wiped dry every thing should be fine.It all depends,try drying it out thoroughly, letting it sit out with all lens caps and lens attachments removed, battery doorway open. is the best thing you can do. I hope that everything works out for you. God bless...
Aug 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-FX12, not working
if it is out of focus. try holding down the menu/set button while you turn it on hold it for about 5-10 sec after it comes on it worked with my DMC TZ3
Jul 01, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
Panasonic Lumix lens does not open all the way
Lumix len goes in and out then I'm told to shut off
Jun 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Ost instruction maual for panasonic DMC-TZ3
You can download them here
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
May 08, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 shutter doesn't close all the way and gives message "please turn camera off then on again"
My camera got dropped into the dirt. The dirt grains are detrimental to the plastic mechanics of the lens system, they imbed themselves into the plastic and become like sand paper. I took my whole camera apart - something that I would not recommend but I was desparate. I don't think I can save my camera, it needs a new optics.
If the shutter has problems it is most likely that the thin aluminum casing at the front of the lens got bent and you may be able to bend it back with a thin screw driver, that you can manage to insert between the plastic casing of the shutter and the aluminum cover. Just where the aluminum casing ends at the front of the lens. But be careful, you may otherwise damage the aluminum and the looks of your camera. If you got dirt in there, you may want to manually (carefully) open the shutter when the camera is shut off, let it close, etc. while blowing air between the gaps of the shutter blades. You can buy a 'Cleaning Duster' spray bottle from Office Depot and use that. But be carefull to hold the bottle straight, don't tilt it or the liquid content will spray over your lens and you have to clean the oily residue with a solution of soap and water (I had to) and wet a paper tissue (use a Kleenex that is not impregnated with a lotion, on the back of the box it will tell you 'Not recommended for cleanig eyeglasses'.
Hope that helps.
Stephan
If that doesn't work, then you may have to send the camera in for repair.
Aug 30, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
160 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
