Question about Pioneer PDP-6020FD 60 in. Plasma TV
Pioneer tv Kuro PDP-6020FD does not turn on
The main red button that shows that tv is turned off is flashing.  It flashes 7 times and stops then repeats.  I tried unplugging and plugging back.  TV almost turns on for half a second and then shuts off again.  There is nothing in the instruction manual as far as I can see to help me.  HELP!!!
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
PDP - 436PG display turns off then straight off and the red standby flashes 3 times, pauses then repeats
That is an error code that likely means power supply issue and based on brand not likely to be a do it yourself fix. Consider having a authorized Pioneer service center look at it and get an estimate.
Nov 05, 2012 | Pioneer PDP-4360HD 43 in. Plasma...
Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Why will my pioneer pdp 6020 not power up?
make sure it doesn't have a vacation button underneath. I have had kids or movers inadvertently press that button and tv goes dead. outside of that. you have lost the power supply and will need professional help. pioneers are very sophistcated
Dec 02, 2017 | Pioneer PDP-6020FD 60 in. Plasma TV
When should the cooling fans come on on my pdp 6020fd
There is an internal temp sensor within the set itself. If the tv is warming up and you hear no fans then the sensor will need replacing before you run the tv long-term. If you fail to replace the sensor your tv IS overheating and can lead to a dead tv very quickly!
Please rate if this has helped you :)
Mar 08, 2011 | Pioneer 60" Plasma Tv Kuro Krp600m...
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Broken plasma
The screen will cost more than a brand new set.. Scrap the boards and sell them on ebay to recover some funds. A new panal is just way too much money.
Sep 06, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Pioneer PDP-6020FD 60 in. Plasma TV Logo
119 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
