Question about Fisher and Paykel DEGX1 Electric Dryer
The smaller heater coils burnt up on my DEGX1 dryer. I removed it and then had to plug the wires that went to the smaller coil into the larger coil to make it heat. It seems to dry just fine on the one larger coil. Is this setup dangerous?? All the thermostats/sensors are still in place.
    Sergeant:
  • 212 Answers
Need to replace entire heating element. possible fire hazard.
Posted on Jun 20, 2009
Dryer blowing only cold air
With the dryer unplugged, attempt to remove the panel that covers the heater coils...either the coils went bad or the "hot wire" lead to the coils burned up and came off, which in that case all you would have to do is reconnect the hot wire.Had this same problem with my dryer a few years back and it had a burned up lead to heater coils.Hope this helps
Oct 24, 2011 | Samsung Dryers
I have a GE DWSR405EBWW Electric dryer. It stays hot after completeing cycle (coils still energized). I opened the unit and coil doesn't look visually broken or grounded. 3 thermostats, 1 is a 4...
The way to check the element for being grounded is UNPLUG THE DRYER remove the wires to the element and check eact terminal individually to the heater housing if any ohms at all from each terminal to the heater housing the element is grounded.
As far as the t-stats 2 of them should have zero ohms and the one w/4 terminals the two larger outer ones should be zero ohms the two smaller inner ones will have somewhere between 100-1000 ohms what the smaller one is a heater inside of the t-stat so when set to delicate the t-stat heater heats the t-stat so it trips sooner on the low heat setting since it(t-stat) gets hot sooner
Aug 06, 2011 | Dryers
I pressure washed my f-250 today including the engine to remove salt and dirt from plowing and shortly after it went into limp mode and subsequently stalled and will not start, I have a heater running...
you have a wet coil pack possibly. use hair dryer to dry the engine coil pack. if you're not familiar with coil packs, they replaced the old type distributors. water has built up in coil pack or you've blown off a spark plug wire from coil pack while pressure washing engine.
Dec 30, 2010 | 2008 Ford F 250 Super Duty 4WD
I have a DEGX1 dryer and it will not heat on any setting.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat. Also check your fan blade on the blower to make sure it has not malfunctioned or broke.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum.
Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Oct 01, 2010 | Fisher and Paykel DEGX1 Electric Dryer
No heat in cloths
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
Sep 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have a GEQ9800PW2 dryer and it is not heating. Can you e-mail me the instructions as to how to change out the heating elements?
You will need to open the back and look for burnt wiring or a bad heater coil. Unplug the drier.Pull the drier away from the wall, unhook the vent hose and remove the back protective cover. Looking closely at all the wiring, you may need a vacuum to get any lint out of the way. Check for burnt wiring to any control switches, most times they will burn at a terminal, all you have to do is replace the wire end, you can buy crimp on terminal ends from most any parts store. Next if no burnt wiring is found you have to check the coil. Look for large wires that hook to large terminals. You may need to get your hands on a Volt/Ohm meter to check the coil for a break in the coil. Remove the wires and read in ohms for a open circuit. If you get no reading you have an open coil and it will need to be replaced. Also it can be the timer but it is rare if all else is working.
Dec 07, 2009 | Sewing Machines
Dryer will tumble but no heat
Dec 07, 2009 | Audio Players & Recorders
Dryer runs but no heat
Check you lint filter, exaust hose for a lint build up first, sometimes this causes a problem like you describe otherwise.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 16, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer won't start
SOUNDS LIKE THE HEATING ELEMENT.
Oct 15, 2008 | Amana NDE2330AY Electric Dryer
Heater coil
have to remove drum to acess hater coil ..all ge dryers are behind drum ck continuity first also ck for burnt wires
Sep 04, 2008 | GE Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
158 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
