Question about Philips 50P8341 50" Rear Projection Television
Power light always on but no pic
After i unplug my Phillips 50p8341 and plug it back in, the power LED immediatley comes on and there is a clicking sound, but no picture ever comes on
    Problem Solver:
  • 6 Answers
Make sure it is off when you unplug it, do not use for at least a few days then.try again. It worked for mine.
Posted on Jun 20, 2009
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a pth5498 when u plug it in tv doesn't come on just makes clicking noise no tubes light up or anything just sound and front power light....
There could be many items that can cause that symptom. However I always assume convergence on any rear projection which can easily be checked by unplugging the convergence amp board and then plugging in the set and press power , if the set powers up turn it back off, and you will know the convergence ICs and associated resistors on that board have failed. Although its easier to replace the board unless you have good soldering skills. I am pasting a pic of the board which is suspended above the main chassis just mark the wires then unplug the set from the wall first, but then unplug the wires from that board and then try powering up the set.if you need further assistance , respond to this same post slinteriors_21.jpg
Aug 12, 2011 | Akai PTH5498 54" Rear Projection...
My phillips model #32PFL5332D/37 flat screen will not come on
You have been the victim of a power surge. It will need to be repaired in order to work.
Sep 29, 2017 | Philips Televison & Video
I have a phillips model 60PP9202 that will not power on at all. Is this unit equipped with any fuses?
The fuses are probably good as you can check...The big solution is you have a weak or bad small signal board. About the size of a deck of cards, located in the back on the left hand side, you will see this when you open the back cover. Try this, leave your tv unplugged for a few days or even a week or two. Then plug it in and see if it will come on....if so the answer has been said. Be patient my friend.
Oct 01, 2009 | Philips 50P8341 50" Rear Projection...
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Phillips # 50p8341 comes on everyonce in awhile. Sometimes it wont come on and the power light will start to blink
Hello! Your set needs the board that has the microprocessor on it. It is called the "process pcb" and is located on the left side as you look into the back of your unit {with the back cover off, of course!). It stands straight up and is plugged into the signal (or "tuner"pcb). They cost about $100 and are available from tritronicsinc.com. All you have to do is unplug the board from the connector by pulling it straight up. Then you just plug the new board in. Make sure it seats properly. The board is approximately 4" by 4" square. VERY easy repair...you can do it and save BIG $. Just make sure you do it when the ac is unplugged!!! Good luck!!!
barneyluc
Oct 10, 2008 | Televison & Video
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
Philips 50P8341 50" Rear Projection Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
