Question about Whirlpool Duet GHW9150P Front Load Washer
Hot water is always used, no matter which cycle I choose
Even when I choose cold, cold, cold the clothes are hot when I open the door to put them into the dryer. I am trying to avoid wasting hot water and the machine has a mind of its own!
    Problem Solver:
  • 14 Answers
Maybe your cold water valve needs changimg
just a thought hope this helps you
Posted on Jun 20, 2009
    Sergeant:
  • 212 Answers
Replace inlet valve
My whirlpool gold series dishwasher will not stop running through cycles unless i open the door. It will just continue to run for hours. Any relatively easy fixes before i call backup?
Some dishwashers can run for 4 hours or more normally depending on the options you choose. What do you mean by it runs through cycles is it always changing cycles by itself or is it just the cycle you pick just keeps on going, have you tried a quick wash or 1 hour wash does it do it then? is you hot water hot enough? if not it makes the unit run longer because it has to heat the water up. always run the hot water at the sink to bring hot water up from the water heater to the sing so the dishwasher fills with hot water and not cold.
Dec 28, 2016 | Whirlpool Dishwashers
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
RE Whirlpool Mod WTW8200YW0 top load, there is always soap left on clothes in the washer no matter type and amount of detergent my wife uses. Any ideas?
Check the water suppl lines to make sure they are not hooked up backwards the rinse cycle uses cold water if the temperature sensor detects hot water it will stop power to the log valve if hooked up correctly then place unit in a rinse cycle to see if rinse valve is opening
Jan 26, 2015 | Whirlpool Washing Machines
Smelly clothes
It is because of the front loading door..
It seals shut - so after you do a load and shut it,, midew forms in certain areas..
Run a white load and use bleach..
After wash - (as all washes) leave the door open..
This might have to be repeted a few times - but it WILL go away..
Remeber to leave the door open after every load..
Have a nice day ;o)
Aug 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My washer won't go through it's cycle. The door
If you do not have both hot and cold water lines hooked up, some cycles might not work. Also, if you put too many clothes in.
Jun 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have tried several times to use cold cycle and the clothes always come out very hot this even happens on the warm cycle. Why wont my machine except cold water?
this can get indepth but first check your hoses and make sure cold is cold and hot is connected to hot. then check the valves by selecting a hot cycle and check water at filling to see if it was cold or hot, if your unit has a heater make sure you dont select sanitize or very hot. then post correct model and heater info. to advise further
May 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water Temperature
you have the water tubes connected wrong way round ie cold to hot and hot to cold - honest. change them over and bet its cured
Apr 20, 2007 | Whirlpool LHW0050PQ Front Load Washer
Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Dec 17, 2006 | Miele Novotronic W1918A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
